Hi GR Fam!
Welcome to a rundown on my GRWTF build. I pick up the car just before Christmas (if all goes to plan). I come from a BMW background but wanted a change so I am really looking forward to this car and the build. It will be something I plan to keep for many years but also drive the hell out of as my weekend warrior, hill climb, and track day car.
2021 Black Australian Pov Pack! I could have picked up a 2nd hand Rallye but when I found this 13km dealer new example I knew it was the one. Also with the below build, the circuit pack really would have been a waste in my opinion.
I have parts coming in from all over the world so making a checklist as things come in is essential for my anxiety
My philosophy is always chassis and suspension first, then power after. As you can see I won't be touching power until I think I need it. But driving a slower car fast is much more rewarding and engaging than a faster car slow, well for me at least
I will be documenting the build here and via Instagram @GRWTF
Thank you for reading!
- PPF full front and entire ceramic coat
Lithumax Restart 7Custom Weds TC105X EJ Titan 18x9.5 ET40 with Yokohama AD08R 265/35R18- AP Racing Pro5000R BBK (depending on rotor width clearance due to front arms)
Endless padsWiborg Engineering Circuit geometry front armsCustom Wiborg Engineering MCA RED Coilovers with pillow-ball top mountsAIRTEC oil coolerRotheli Racing Titanium brake shims (Phil you legend!)AP Carbon Arch GuardsTGR Performance shifter riser 2.0 (may go CAE if I am not content with just the risers)TGR Performance mirror riser 3.0Foresight short shifterATS Carbon LSD's front and rearXtreme Clutch HD OrganicCusco power brace front member rear (the front brace doesn't fit with the undertray cooling unless you go with the GR brace kit $$$)DNA Racing uni-ball rear support arm bushingsDNA Racing uni-ball rear swing arm bushingsCusco strengthened pitch stopperCusco rear diff mount collarCusco front diff mount collarCusco rear power braceCusco diff coverCusco rear member collarCusco sports accelerator pedalSpoon front and rear rigid collarsGazoo racing undertray coolingGazoo racing brake ductsGoodridge brake linesHard race rear upper camber armsHard race rear toe armsPIAA HornsStern Performance rear seat delete- OMP HTE-R seat
- N Sport S1 seat rail
- Kelford Cams and springs
- Plazmaman Supercore FMIC with upgraded 2" high-temp piping OR Wagner Competition IC kit
- GRP Engineering stainless 4.5" dump pipe and 100 cell cat into 3" straight mid-pipe (will test with factory cat-back first for noise)
- All Type Fabrication intake
- DTUK Stage 2 (unless a flash option is developed in 2022)
