GR86 GR86 Fake Engine Sound On/Off Comparison
Excellent video. The difference is quite pronounced and personally I'm not quite sure what I prefer yet.
The boxer engine doesn't sound the best so I'll probably end up leaving the sound amplifier on for a bit and after getting used to it, switch it off for real life comparison. But the fake noise wouldn't bother me too much judging by this video.
That's a really good comparison. I'll be interested to see how it sounds in real life, it's quite intrusive though isn't it. It's highly like I will unplug mine.
I think I would leave it on most of the time, but for a long motorway journey I think I would prefer it off, like the idea of a switch though.
Great comparison. Such a neat idea to to wire it into a switch. I don't understand why they didn't just make this an option you could turn off yourself in the menu rather than having to get a dealer to do it, or unplug it.
i will unplug mine once i have my drop in, i guess
I’ll be installing a switch I think as I certainly wouldn’t want that drone at constant speed on the motorway.
Have to bare in mind he was in 4th and 3rd crusing at motorway speeds, in reality you'll be in 6th much lower in thr RPM range where active sound isn't doing anything.
With the gt86 acoustic pipe was actually useful feedback from the engine. Even at 6th gear one could hear direct injection being engaged. You could gauge if the engine was struggled. Not sure how the fake one works in the gr86
Sounds better when it's on! Although I have an APEXi on route so may disable it then so I can hear my new exhaust.
How much would it have cost to put a few extra lines of code in the settings menu to make it switchable via the onboard screen?(n)
With my GT86 I remember plugging the sound tube and realising the car lost its should when quiet. So I let it pump the acoustic sound and can't do without the engine note now. I hope the fake one is not horrible.
As a software engineer i can say: not much.
The functionality is there, it is only hidden/not exposed, because dealers can enable/disable it.
So the only thing, that has to be added is an option in the specific menu.
The headunit uses QNX (thats stated in the manuals licenses part).
Would be 2 lines of code:
Something like this
Code:
fakeNoiseSwitch = new Switch(labelId, functionToTrigger);
whatever.add(fakeNoiseSwitch);
Also the localisations/translations should be available (because that switch exists), mabe the text is too long, so you would need a new text for every language.
With testing ect, this should take less than a day.
I cost ~1000€ a day...
if its part of a regular update, there would be no more costs...
Reactions: v8s
This video provides a good direct comparison. The owner installed a toggle to switch the sound on/off while driving.
My dealer said they can toggle it off in the software FOC if I want. I like hearing what the engine is doing but not a fan of piped noise through a speaker. To me it sounds a bit “boomy” with it on so will probably get turned off and see how I go.
