Michael Knight
If not double thought of sharing regular maintenance plan for GR Yaris.
6,000 miles £165
Intermediate Service 6,000 miles/1 yearRecommended
We recommend that Toyota owners carry out a 6,000 miles/1 Year intermediate service as per schedule. Scheduling regular service appointments as per your vehicles service schedule helps maintain the health and longevity of your vehicle whilst helping prevent maintenance issues down the road.
Carry out 6K/12 month intermediate service as per schedule.
Includes:- Replace engine oil & oil filter.
Replace windscreen washer fluid.
Check all fluid levels & top up as required.
Inspect battery for leaks, security of clamps & terminals.
Inspect cooling system, hoses & connections.
Inspect radiator & condenser for debris & signs of damage.
Inspect clutch fluid.
Inspect brake fluid.
Check wheel nuts for correct torque specifications.
Inspect brake pads & discs.
Inspect pollen filter.
Inspect steering wheel, gear & linkages.
Inspect for under vehicle and underhood fluid leaks.
Inspect tyre condition & inflation pressures.
Check brake & clutch pedal travel.
Check operation of lights, horns, wipers & washers.
Check function of all warning lights.
Check seat belts for damage & operation.
Check installation of drivers floor mat.
Carry out wash & vacuum.
Carry out visual safety report.
Carry out final inspection & road test.
12,000 miles £375
Full Service 12,000 miles/2 yearsRecommended
We recommend that Toyota owners carry out a 12,000 miles/2 Years full service as per schedule. Scheduling regular service appointments as per your vehicles service schedule helps maintain the health and longevity of your vehicle whilst helping prevent maintenance issues down the road.
Carry out 12K/24 month full service as per schedule.
Inspect drive belt.
Inspect air filter element.
Clean air flow meter.
Check brake pipes & hoses.
Inspect fuel cap, fuel lines & connections.
Inspect transfer case oil.
Inspect rear differential oil.
Inspect drive shafts including CV boots.
Inspect ball joints & dust covers.
Inspect wheel alignment.
Inspect wheel bearings.
Lubricate propeller shaft & tighten bolts.
Inspect front & rear suspension.
Check exhaust system for security & leaks.
Check wheel rims for damage & tighten wheel nuts to correct torque.
Check operation of hand brake.
Inspect glass and light lenses.
Replace pollen filter.
Check operation of alarm system.
18,000 Miles £165
Intermediate Service 18,000 miles/3 yearsRecommended
We recommend that Toyota owners carry out a 18,000 miles/3 Years intermediate service as per schedule. Scheduling regular service appointments as per your vehicles service schedule helps maintain the health and longevity of your vehicle whilst helping prevent maintenance issues down the road.
Carry out 18K/36 month intermediate service as per schedule.
24,000 Miles £375
Full Service 24,000 miles/4 yearsRecommended
We recommend that Toyota owners carry out a 24,000 miles/4 Years full service as per schedule. Scheduling regular service appointments as per your vehicles service schedule helps maintain the health and longevity of your vehicle whilst helping prevent maintenance issues down the road.
Carry out 24K/48 month full service as per schedule.
Inspect drive belt.
Inspect engine coolant.
Replace air filter element.
Inspect charcoal canister.
Replace clutch fluid.
Replace brake fluid.
Inspect manual transmission oil.
Replace transfer case oil.
Replace rear differential oil.
Replace remote control battery.
6,000 miles £165
12,000 miles £375
Inspect drive belt.
18,000 Miles £165
24,000 Miles £375
Inspect drive belt.
