Silver Fox
- May 7, 2022
- 3,626
- 8,351
Yeah merry Christmas mateToyota paint is notoriously poor - easily fixed though so don't pamic. Not a great time of year to collect a new car though, itl be ruined before the good weather returns
I haven't used a clay bar for a long time, but when I did I used to buy the Meguiar's clay kit, which came with a bottle of quick detailer (I think it was called) for that purpose.What do you folks recommend for lubricant when using a clay bar?
Bought a clay bar today, some of the autoglym tar remover and a pot of the Meguiars Ultimate Paste Wax as it was recommended by a friend of mine.... £38 retail at Halfrauds for the wax but only £20 with my trade card... that's a result even if £20 is still quite a lot for polish IMHO ;-)
Quick detailer would work, if you have any rinseless wash that works well - you could even use diluted shampoo (just don't let any of it dry out) - clay can cause marring to the paintwork - it's often used as part of a decon before a full polish - just be careful - the ultimate paste wax doesn't have any 'cut' to it to remove marring (I don't think, I've not used it personally) - perhaps try it and your technique on a bit of paintwork you can't see before you commit fully??What do you folks recommend for lubricant when using a clay bar?
I would not recommend using a clay bar if you're not intending on polishing the paint between the clay barring and waxing. It will cause micro-marring otherwise, especially if you're not experienced with using one. The Meg's Ultimate Paste Wax you have linked is just a wax, it does not have any polishing qualities.What do you folks recommend for lubricant when using a clay bar?
Started watching his videos recently, some useful tipsAs others have said, the likes of QD can be used as a lubricant but make sure you use plenty of it. There's a guy on Youtube that I follow 'Epic Automotive Detailing' - he has a video on using a Clay Bar HERE
I’ll try the clay bar and the wax on the ePace before I advertise it.. I’ve got some Autoglym polish to apply before the wax if I need itQuick detailer would work, if you have any rinseless wash that works well - you could even use diluted shampoo (just don't let any of it dry out) - clay can cause marring to the paintwork - it's often used as part of a decon before a full polish - just be careful - the ultimate paste wax doesn't have any 'cut' to it to remove marring (I don't think, I've not used it personally) - perhaps try it and your technique on a bit of paintwork you can't see before you commit fully??
All the above is only opinion and trying to be helpoful, not meant as critique of either ability or products.
Hmmm I might just look for a detailer locally to sort the cad out once it’s here.. I’ll use the clay bar on the current car but may return the wax .. Thanks for the tips.. Thanks to the others who took the time to reply tooI would not recommend using a clay bar if you're not intending on polishing the paint between the clay barring and waxing. It will cause micro-marring otherwise, especially if you're not experienced with using one. The Meg's Ultimate Paste Wax you have linked is just a wax, it does not have any polishing qualities.
There are other, less intrusive methods of decontaminating the paint. Shampoo diluted with some strong APC followed by an iron fallout remover might be the way to go if you want to strip down any significant surface contaminants before waxing.
With regards to the tar remover, I would only recommend using it on very stubborn contaminants like tar, glue or caked on bugs or tree sap after a paint decon and wash. It's a fairly strong chemical and you definitely should avoid it coming into contact with any plastic parts of the car, or your skin. And don't use it indoors, as most have a very strong scent and are bad for your repiratory system.
I thought I’d read that the tar remover was the right product for removing adhesive remnants from the white film that the car has fitted when it’s in transit.. To be honest I’d probably have let the dealer clean the car before I collected it but reading the forum put me off a littleI would not recommend using a clay bar if you're not intending on polishing the paint between the clay barring and waxing. It will cause micro-marring otherwise, especially if you're not experienced with using one. The Meg's Ultimate Paste Wax you have linked is just a wax, it does not have any polishing qualities.
You don’t have to have it coated. A lot of decent detailers will offer a ‘New Car Detail’ (or similar named) that will just involve a thorough decontamination, 3 bucket contactless wash, paint correction (stage 1 machine polish) and finish with a wax and/or hydrophobic spray. These tend to be several hundred pounds cheaper than Ceramic Coating.I’ll check out detailers near me but hadn’t planned to go down the PPF and Ceramic route..
A local detailer has quoted £450 … I’ll invest in the foam Lance and products for that price and do it myself.. How hard can it beYou don’t have to have it coated. A lot of decent detailers will offer a ‘New Car Detail’ (or similar named) that will just involve a thorough decontamination, 3 bucket contactless wash, paint correction (stage 1 machine polish) and finish with a wax and/or hydrophobic spray. These tend to be several hundred pounds cheaper than Ceramic Coating.
450? What does the include? That's an absolute bargain.A local detailer has quoted £450 … I’ll invest in the foam Lance and products for that price and do it myself.. How hard can it be![]()
“It would be £450 to decontaminate, single stage machine polish and apply the appropriate exterior/interior protections.450? What does the include? That's an absolute bargain.
