GR86 GR Centre in North East? Pro's and Con's
grzoostuff
UK North East
Hi All,
1. Does anyone know which is a GR centre in the north east, it's showing up as Gateshead only or does it mean any Stoneacre branch?
2. Does it make any difference for servicing if you use a GR centre, would they have all the best kit setup for GR cars?
Cheers.
Gateshead and Stockton are listed on the test drive invitation. There's also a dealer in Hull depending on where you are in the NE.
Hi All,
Cheers.
TBH unless your GR is broken I can’t see why any competent Toyota mechanic can’t service it correctly and it’s probably a lot less complicated than the hybrids. If anyone was pulling the engine apart then that’s a different question 🤔
