GR Yaris Geometry Setup West Sussex / Hampshire ?
LSToyGR
Fascinated Member
Hello I’m looking to get GR Yaris Eibach lowering springs and String Theory wheel spacers. Can anyone recommend where to get the geometry setup after.
Preferably West Sussex / Hampshire area.
Thanks!
Abbey Motorsport in Oxted are brilliant, they have done all the set up work on mine. Surrey but not a million miles away
Same Abbey Motorsport Oxted did the same set up to my car and some of my friends , very good
  • AW Motorworks, Essex. Long established and have done a brilliant job on a few GRYs of expert owners I trust. Haven't tried them.
  • TGM Sport in Fleet, Hampshire. With motorsport/racing experience too. They've done Eibach lowering springs on at least one GRY. Haven't tried them; so, I would need to check with them regarding geo specifically.
  • Abbey MotorSport, Oxted. While there's no doubt about their ability to do an alignment, there's room for improvement in terms of customer experience. Also:
  • Precision Alignment, Junction 3 M25, Brands Hatch Exit. Haven't tried them. No idea about their pricing.
  • Horsham Developments (h-dev), Berkshire; so, not in Horsham. Haven't tried them. There is a mention to pricing on their website.
I'd also recommend Abbey. They've done both of my GRYs. Customer service for me has always been brilliant.
Do you guys recommend front camber bolts?
Phoned Abbey Motorsport and they recommended camber bolts front and back
Yep. They initially did mine without, but on my second car they needed the bolts to get the fast road set up done properly.
Depends on what you're looking to do (and achieve), at the front (and in general).
If it's adding just a bit of negative camber at the front or even setting it at a bit higher negative setting than the rear, I don't think you need rear bolts.
If you're going aggressive at the front, not adding negative camber at the rear too risks creating a front-rear imbalance that may render your car dangerous.
There are various views posted about the maximum front rear difference: for example, I recall max 0.4, 0.5 and 1 degree.
Your query suggests to me that you haven't figured out what you want your geo settings to be and why. Based on that, I would suggest taking a step back and researching on (aggressive) geometry settings and their implications and risks. I found it fascinating and definitely a learning curve worth going through.
It also gave me a chance to appreciate the risks associated with setting your geo outside of Toyota recommendations (which you will almost certainly do, if you're going for aftermarket bolts and recommendations that include rear bolts too). Nothing wrong with that, as long as you know what you're doing.
Plenty of really useful info on the subject, here and elsewhere.
Thanks 😁 all I want is the car to feel like standard/fast road.
I didn’t know that when fitting lowering springs you then had to adjust the alignment settings.
Abbey did my car and did a fantastic job , it’s fitted with Eibach Springs , front camber bolts set to fast rd not track , string theory spacers and they have the Hunter alignment system , car looks and drives superbly, they have carried this work out to lots of Gr Yaris
You can go with a little extra negative camber on the front and leave the rears. You don't need the bolts for this. My suggestion would be to see how you like the handling with just the springs and spacers first and then see how you go. You'll probably find you don't want more than this.
Abbey Motorsport also did mine with front camber bolts only. I am also in West Sussex.
