GR Yaris First track day - top tips
Sturesmyg
pianofingerpower
Hello!
Doing my first track day on Tuesday. Car has 9000 km on the clock. Anything in particular I need to do/prep car wise?
Just check the oil and coolant levels, and start the day with the recommended tyre pressures. After your first few laps reduce the pressures to maintain them at the point you started at, but don't forget to reinflate them before you leave for home. :)
we have track driving related topic here
I'd say familiriaze yourself on getting the driving line correct, so that you get right flow into corners. then you can start progressively incrase speed if your line is correct. as for line hints also from more experienced drivers. Watch out that lift of oversteer in fast corners, it can catch you out.
Remember to cool car down properly after fast laps as it gets hot and there is no extra cooling if car is idling / shut down.
Thanks this is the kind of tips I’m after. Will be getting lessons with an instructor, so he/she will help me with the driving part.
I’ll check coolant and oil!
Try and get instruction first, this will get you the correct lines and start correctly rather than fixing your mistakes.
Don‘t hog the racing line, if there are faster cars on circuit let them passed, it‘s not a race and you’ll get home safely.
Brake hard and for a short time, preferably in a straight line.
try to do a few laps more often (rather than long stints, if it’s your first time 3-4 laps will be more than enough) giving the car time to cool down, the car will get hot and road tyres go off quickly.
Recommended to take oil, water, torque wrench and air compressor.
check wheel nuts after each turn on track, they get very hot and might come loose, if you adjust tyre pressure as they get hot when you want to go home they will be low so pump them up.
Towing eye in before entering track.
