The bit I'm most impressed about is that it appears to have introduced a bit of the Subaru burble. That's not something I've heard in any other system without UEL manifolds.
Alburrito, Manchester area. You're not the roll it up, decorate it, salt-flake it and bake it guy are you?Howdy all - first post here (I think!).
I've had a Remark axle-back on my 86 for 12 months and whilst it was fun to begin with I quickly began to hate it - moving to a tight terraced street did not help. It wasn't even that it was loud (which it was), it just sounded bad to me and droney as hell.
Anyways I took the remark off at the weekend and driving without the noise was honestly bliss, aside from not being able to hear my revs at all.
It's making me question what I want to do next. I've had my heart set on a Spec L2 for a while as I love how it looks and want something on the tamer side, but I'm struggling to justify the cost relative to other options and I'm now thinking Cobra.
I was also going to get catless UEL headers and a remap done but I'm really not sure this car needs it now, whereas my old GT86 definitely did. If I was going that route I would definietly go resonated, but now I'm not sure. I want to hear something!
I've recently move to Macclesfield (glad to see some of the good reviews for RRG here) - I was wondering if there is anyone within a reasonable distance with a Cobra res or non-res installed that might be willing to meet up so I can try to make a decision.
Also - if anyone has a Cobra or HKS/similar that may be up for sale soon let me know!
After living with the PCW modded exhaust for a while now I’m still really happy with it.My remark axle back is coming off in the next few weeks as well.
I’m heading to PCW exhausts to have my stock system modified, sounds immense and not that expensive either.
Its definitely a buzz killer. You can't have a nice moderately entertaining exhaust without your neighbours thinking you're a complete tw@t. I dont think it's a worthwhile trade off at all (for my neighbours) if you consider the pitiful emissions gain.The only downside, as with all modded exhausts on this car, is the cold start.
My lunch time web browsing at work consisted - as it does very often - of me trawling various forums and web shops looking for a front pipe solution which will allow a GR86 to pass an emissions test when a catless manifold is installed. I'm aware of the GPF being a thing, but if we presume the car would pass visual inspection providing there is a visible emissions device in the front pipe, the emissions test is the only hurdle.
I've ended up reading quite a lot of posts on old GT86 forums, where there appears to be a lot of familiar user names. Many of you had some useful things to say. The general consensus is that most aftermarket front pipes will not be sufficient for the car to pass an MOT emissions test. Some sources say that the Berk unit is sufficient, other say it isn't.
The Berk and HKS front pipes both have a 200 Cell cat, although I know not all Cats are created equal in terms of quality. The AVO front pipes, which have a large 5 inch cat which would be great for flow seam to use 160 Cell cats, which I'm fairly certain will never be enough to pass an emission test on their own. There was mention of units made by Rogue motorsport, but they seem to be a custom motorsport outfit and they don't have any front pipes in their web shop. Maybe it would be worth giving them a call.
I also don't want my car to be insanely loud and raspy (It's already quite loud), so ideally there would also be a resonator in the front pipe. To further complicate things, I'm still keen on getting a turbo kit fitted (probably early next year) so it would be ideal if it was a 2.5 inch or 3 inch pipe.
The more I Look, the more I seem convinced that the best solution to this conundrum (without putting the standard manifold back on) is to either get a Gen 1 OEM front pipe for testing time, or see if I can get a custom front pipe made up. If any of you, especially if you had a turbo Gen 1 car, can offer any advice I'd really appreciate it, and it would stop me wasting endless hours looking at every shop in the world that sells front pipes.
Seems we are both searching for a front pipe solution then.
Im thinking HKS 33004-BT003 with the res/cat in it (not actually sure which...) with a map to get past the lack of pressure sensor pipes, and swap in the OEM front pipe come MOT time. Only other option is the Supersprint front pipe (with cat and the pressure sensor pipes, but the cost of it is insane.
Definately not for me of course, for a friend.
High flow cat in the headers and high flow in the mid pipe (or a res) without the OPF, he feels it would be too loud and antisocial with anything less than 2 cats.I had a “not for road use” Supersprint system on a car many moons ago. The quality was fantastic but it was massively antisocial on the volume front and definitely not something I’d tolerate now 20+ years older
Is your “friend” aiming to go with the HKS front pipe to sack off the EU OPF and go with a catless header or effectively stacking high flow cats in the header and front pipe ?
Thanks Martyn, great to hear the C-TEC system is ticking all of the boxes for youIt is a stunning piece of engineering. Done probably 2k in mine now and it's well bedded in and sounds like it always should have stock.
Mine is due tomorrow, this gives me hope!Just wanted to share that the GR with the Remark axleback got through the MOT just fine, even as loud as it is![]()
