GR86 Exhaust Gasket Assistance
Delahorney
South Wales
Hi all,
Took my remark axle back off to put the standard exhaust back on and the gasket that was there has crumbled into a million pieces.
After some research I ordered this from my local dealer: https://toyotadirectparts.co.uk/pro...esent-exhaust-back-box-to-centre-pipe-gasket/
Having now come to fit it, it seems this isn't the correct part as it is too small and you cannot get both bolts through the holes. The main exhaust hole is the correct size however.
Does anyone know the part number for a GR86 exhaust gasket that sits between the back box and mid pipe?
Thanks
That looks the right part number going off amayama too. It looks like the one on the Yaris too, does the pipe / back box have a recessed bit for it to sit in? If so, it's probably right
Sorry Mike, do you mean the first part or the second? I believe there is a recess for it to sit in, yes.
Ignore me, I was being thick and hadn't checked Amayama (great site, didn't know about it previously).
Will order SU00306425 tomorrow and try it all again.
