Expired Drivers seat
Status
Not open for further replies.
Hardcover
Looking for drivers seat to replace the passenger seat in a left-hand drive car.
I do not think it is that simple… The passenger seat in the RHD cars has an occupancy sensor, the drivers side doesn’t as the logic is if the engine is started and car in gear someone is in the driving seat. I suspect the logic will be the same for LHD cars. Therefore you will not have an occupancy sensor in a LHD car drivers seat?
I have both seats available taken out at 1k miles for Recaros. Shipping to Germany might be tricky though.
Occupancy sensor shouldn’t matter or cause a dash light, just the airbags which need a resistor if swapping out for buckets.
Why shouldn’t the Occupancy sensor matter? Agreed leaving it unplugged will not cause a light on dash, and the resistors will also trick the system from triggering an airbag fault light if you are using seats without airbags…. But if the occupancy sensor is left unplugged as no longer an occupancy sensor, then if someone is in the passenger seat and you crash, then the passenger dashboard and/or side curtain airbags will never go off… To me that’s dangerous. I have seen devices to plug into the occupancy sensor plug to invert the system, and make the car think someone is always in the seat so the airbags will go off if required in an impact regardless of someone being sat in the passenger seat…. That’s a safer solution.
You could I guess take apart the original passenger seat in your car and swap the seat cushion over with a RHD OEM passenger seat as the original poster is trying to obtain… Toyota integrate the passenger occupancy sensor into the the cushion sponge on the passenger side, and it cannot be bought separately.
Status
