Why shouldn’t the Occupancy sensor matter? Agreed leaving it unplugged will not cause a light on dash, and the resistors will also trick the system from triggering an airbag fault light if you are using seats without airbags…. But if the occupancy sensor is left unplugged as no longer an occupancy sensor, then if someone is in the passenger seat and you crash, then the passenger dashboard and/or side curtain airbags will never go off… To me that’s dangerous. I have seen devices to plug into the occupancy sensor plug to invert the system, and make the car think someone is always in the seat so the airbags will go off if required in an impact regardless of someone being sat in the passenger seat…. That’s a safer solution.I have both seats available taken out at 1k miles for Recaros. Shipping to Germany might be tricky though.
Occupancy sensor shouldn’t matter or cause a dash light, just the airbags which need a resistor if swapping out for buckets.
