Had my car in for an alignment following the fitment of 14mm camber bolts at the front, ended up with the following:
Front
Camber: 2.0 degrees both side
Toe: Asked for 0.1 degree total toe in, got 1.2mm (anyone know how to convert toe in mm to degree?)
Rear
Camber: non adjustable so these are my out of factory values: L 0. 5 deg / R 0.9 deg
Toe: Asked for 0.2 degree total toe in, got 2mm
Whilst I'm not too happy about the asymmetric and rather low camber at the rear (would have preferred something symmetrical around 1.2 deg), I am extremely happy with the result; due to the toe in i think, the car has lost the neurotic tendency to require constant, minute steering inputs just to keep it going straight; it is much more easy going, and FR like to drive. Any loss of turn in agility is minimal, and the improved straight line stability is more than worth it for me.
The increased front camber can be felt mid corner with reasonable lateral loads: front end feels a lot more planted and reaponsive to steering adjustments. Rear end seems a bit more willing to rotate on a mid-corner throttle lift: need to check in the wet but in the dry conditons today at least, it didn't feel excessive.
Still debating whether i should get those rear camber arms to sort out the crap stock settings on mine, but they aren't cheap!!
