Yeah, maybe the biggest takeaway is don't let it go below max so check up regularly if you use the car anywhere near its performance potential. Down to min it's a whole 1l less (acc to the manual) or only ~3,3l oil in there, that's definitely not a good thing! Iirc people doing trackdays have gotten oil pressure warnings with oil only halfway and that's with the insensitive OEM ECU - proper starvationSo am I right to assume that for street use, leaving the oil right at the max mark is probably a good idea?
Dealer tends to leave it in the middle.
I meant oil cooler, not airIf it adds 20hp at peak power 5500rpm that's per definition approx 25Nm and if it succeeds doing that it probably adds the same or more at peak torque around 4000rpm. Not problematical per se but does add load and as such not insignificant if heat load is already high (air cooler, you mean IC? Wagner? In that case that one alone also adds alomost 20Nm.)
What is the actual detailed tuned spec of the failed car?
Just in case you‘re afraid of oil pressure dropping…
Cleaned it with Brake- and Adhesive Cleaner and a rubber disc to remove the rest of the sealant.Just watched the video, what did you use to clean engine under eath beforre nstalling the baffle? Also, do you stil overfill oil after installing the baffle as precautionary measure or not ?
There's no oil pressure issue
And with significant increase in hp (>340). If ayone wants +40% power increase why not buy a car with that stock power and modify one ? The money spent and risk taken will always be greater than geting a car with more stock hp to begin with!Interesting is, that most catastrophic engine failures i‘ve seen so far where with cars that significantly increased the rev limiter…
Because these Cars aren‘t the GR Yaris.And with significant increase in hp (>340). If ayone wants +40% power increase why not buy a car with that stock power and modify one ? The money spent and risk taken will always be greater than geting a car with more stock hp to begin with!
I don‘t even do it with my fully built engine.Maybe its good consideration to swap forged pistons and conrods if aiming higher hp/revs as added cost of hw is not really significant.
Id love the idea of high revving GR but now understand it is not the greatest idea with stock engine.
I get it (higher hp current offerings need also a lot of things to be fixed to make them trackable and certainly come significantly heavier than GRY) but unless you are competing in any form of race (rally, time attacks, etc) for the hobbyist racetrack visitor and using the car on the road, the 300-350 range of hp with a solid suspension setup is more than enough to punch above its size and give the necessary thrills and keep a higher peace of mindBecause these Cars aren‘t the GR Yaris.
A Golf R, BMW M140, Mercedes A35 or whatever else is in that region might have more power but is otherwise not even close to the fun the GR is.
We have built now a couple of GR‘s with 350/380 and over 400hp.
Not a single blown engine so far.
That doesn‘t mean much, but still.
And if you‘ve ever driven a GR with 350hp, you‘ll wish these come from factory with that much power.
It‘s addictive.
And yes, it‘s a risk. So is life in general.
But one you can reduce if you take the right parts for the right power range and don‘t overstep.
