GR Yaris Brake fluids
Michael Knight
Finland
Plan to swap more heat resistant brake fluids.
Have been using Motul RBF previously, now tempted to test Endless - is it better for the price difference?
Endless is claimed to have a better brake feel?
I'm not sure if different brake fluids even influence the braking feel at all besides staying consistent at high temperatures? Motul RBF 660 for example is definitely well proven..
Yeah, no brake fluid is going to be “less compressible” than any other, so in that sense they’re all identical if filled, bled correctly etc.
What the better ones should have is greater resistance to boiling and hygroscopicity, meaning they’ll better maintain that feel under extreme use, and over time.
over time have used all the big name fluids Inc the hugely expensive Castrol react
have now settled on Revenol's fluid along with their oil it's outstanding and sensible priced
what @Duke said pretty much sums it up
What’s the downside to these higher spec fluids? Do they need replacing more regularly?
IIRC it is recommended that it be changed annually.
One assumes, however, if you are using competition brake fluid the car will be driven hard and likely on track. That being the case, the fluid should be changed at least once a year anyway.
hi,
I have had racing fluid in for one year now. Was planing to do it myself but have not been able to find a pressure cap to fit the brake ressivour to help push out the old and add the new. Any body got any ideas apart from going to Toyota dealer?
hi,
Quite a few good indies around the country that are more than likely to have one. Really depends how near you are to one of them I suppose.
hi,
I have had racing fluid in for one year now. Was planning to do it myself but have not been able to find a pressure cap to fit the brake reservoir to help push out the old and add the new. Any body got any ideas apart from going to Toyota dealer?
me personally wouldn't trust a dealer to actually do the job properly so just do it myself pretty easy, use syringe or similar to remove as much fluid from reservoir then fill reservoir right to top with new fluid
two ppl:
open bleed valve
push pedal to floor and keep it there (get confirmation pedal is on floor)
close valve
raise pedal slowly
repeat 5 times per caliper
on twin bleed calipers bleed inner first
DON'T let reservoir go empty as its costly if air gets into ABS system
I bought something like this for my bikes, used on previous cars too, nice and simple one person job
View attachment 15934I bought something like this for my bikes, used on previous cars too, nice and simple one person job
probably with this system is the bleed valve is always loose and even though the hose is in fluid at bottom of jar when lift the pedal air is sucked in around the thread of the loose valve
