GR Yaris Braided lines & race fluid with stock brakes
Spirited
The situation is, after driving as my nickname suggesgts for some time on a warm day (still on the road so not as much strain as track driving), I applied usual pressure on brake pedal, but the bite and braking performance wasn't there. Car is stock in terms of power and major suspension components.
I had front pads changed for the first time around 18k miles and they weren't fully worn, so I thought my use doesn't require a brake upgrade. I guess, I have develeooed since 😊 and the discs must have deteriorated, for what difference that may make.
The three main things I can consider upgrading are pads, discs and braided brake lines/hoses & fluid. I'm thinking I should start with the brake lines.
Question 1:
Am I right to prioritise stainless steel brake lines, or should pads or pads & discs be my priority?
Question 2:
Will good braided brake lines make a difference in the sense of not losing bite after prolonged use on the road, given that I won't be upgrading pads, discs and brake fluid? Or is it pointless to upgrade brake lines without also upgrading eg brake fluid? If brake fluid is a must, then would you recommend a particular one?
Question 3:
HEL or Goodridge and why? I've heard a lot of good feedback for both and fewer concerning comments, again for both. Insights from the old forum suggest that Goodridge test every single hose. Concerns were mainly a report from someone that HEL fittings seemed of higher quality and longevity as well as @DeanoC finding two HEL orders to not be correct.
Nothing much to choose between HEL or Goodrich, both good products and worth fitting.
Would also suggest competition brake fluid such as Motul 600 or Castrol SRF, but keep in mind it requires to be changed more frequently than normal fluid.
My understanding is that stainless vs. normal fittings is just a matter of looking better after extended use. There won't be any difference in performance, and ultimate longevity is probably not any better with the SS items either.
It's basically bling :D Nothing wrong with that, but only you can judge whether the extra cost is worth it for something which is rarely seen and inevitably covered in schmutz anyway.
If the pads were worn then it's likely that the fluid just got a bit hot at some point and is now basically cooked.
Fluid change, braided lines (of any brand or flavour), and maybe those RS3 ducts that @Michael Knight fitted recently would be my approach to never experiencing it again.
Braided lines were one of the first jobs I did, I’ve also recently done the clutch line, all HEL. There’s some good colour choices with them, they fit well too. I am also using Motul RBF 660, as well as some P-Def brake shims.
Bleeding the brakes on a semi-regular basis is a good tip.
... Would also suggest competition brake fluid such as Motul 600 or Castrol SRF, but keep in mind it requires to be changed more frequently than normal fluid.
Thank you, both!
So, what intervals (eg, every how many miles) do you mean when you mention "more frequently" and "semi-regular basis"?
Ok, so your responses seem to have one thing in common, despite me never mentioning it: Frequent brake fluid changes. Point taken; thank you!
And in terms of fluid quality & longevity, price aside, any clear winner between eg:
  • Ferodo FSF050 dot 4
  • Motul RBF 660
  • Castrol SRF
Driving in expert mode on a winding road puts a serious strain on front brakes. My front pads last 2-3 times longer with ESP fully off. Not encouraging you to do that on a public road by any means (I personally do that only on a track), but good to be aware.
Also, I dont know if its just me -- haven't seen too many complaints -- but my calipers will seize in 5-10.000km if I don't do a proper cleaning and pin/slider greasing every 5.000km front and back. Otherwise the pads wont back off, heat up and cause premature wear of both pads and rotors.
I am at 60.000km, the car is fully stock apart from -3/-2.7 camber, 27 track days and spirited driving. Still on original disks, expect fronts to last another 40-50.000km, rears 20-30.000km.
On 6th pad front and just changed rear pads.
What's your thinking behind Expert putting any more stress on the brakes?
Once traction control and / or stability programs start using the brakes to help you get around a corner you'll be seeing accelerated brake wear.
Expert is already much less aggressive concerning that than TC on from what I've felt so the 3x wear vs. TC off seems a bit extreme to me though.
I agree it might be extreme -- the 2-3x wear rate is a track experience
It is constantly braking the front outter wheel in a corner when pushed to reduce oversteer
But ESP is only feathering the brakes momentarily in the turn. Compared to an actual braking manoeuvre, the stress, heat, and wear it causes is negligible.
Does it increase wear vs. ESP off? Yes, but marginally I would say.
My front pads lasted about 35,000 km and I drive in Expert 99% of the time. I don't do much track driving, but never baby the car and I can't say I would expect much more life from a set of pads.
  • Motul RBF 660
  • Castrol SRF
Im using Endless
I seem to recall a YouTube video from Japan mentioning that Expert mode applies the rear brakes at times. I had no idea about fronts.
Applying rear brake in a turn increases oversteer (e.g. pulling the handbrake)
Braking the outter front wheel counters the oversteer.
I guess it all depends on the roads, too: if there are a lots of turns and no straights, the brakes wont have the opportunity to cool as they are working even while cornering
Pushing it on track obviously increases the difference
35.000km is a superb pad life on this car -- I dont think mine would last more than 20-25.000km if I never tracked. About 300-500 track km in expert mode and around 1000 km with ESP fully off to wear down the front pads to under 3mm...
