Pretty worthless rear view mirror. Too wide angle and too bad quality, basically won't see anything approaching at speed until it's too late.I wonder if anyone managed to get the center-screen as rear-view mirror? - as per video below
Apparently seems to be as simple as tricking the system to think that's on reverse all the time... but how?
GRY video
the center-screen tends to be pretty much useless anyways...There's usually a wire carrying 12v when in reverse, just needs changing to a wire with permanent 12v.
Would make the head unit useless unless you put it on a switch...
well - as we all know - the original rear view mirror is not great either... - specially if we consider that impairs the (somewhat important...) front view!Pretty worthless rear view mirror. Too wide angle and too bad quality, basically won't see anything approaching at speed until it's too late.
More work but imho much better solution (I can compare both on a daily basis when reversing, one is worthless for tight reversing, the other one is worthless to see anything more then 20m away):well - as we all know - the original rear view mirror is not great either... - specially if we consider that impairs the (somewhat important...) front view.
Anyways, I'm willing to try - so if someone has useful tips /wiring /software tweaks how to achieve this, I'm all hears!
-Thanks, maybe just need then to find the correct wire (to trick the screen unit) when toggling some "reverse-button"... in the long run maybe another type of camera to replace the original (not as wide-angle /not tilted-down so much) may improve it even further.I have my 4wd set up this way when towing the camper. Aftermarket head unit not factory Toyota. Set up with a separate switch to provide power to the camera so it only operates when the switch is pressed (and head unit is selected to camera 2). If you supply 12V to the camera without disconnecting the reverse lights signal those lights will be on whenever the camera is operating. With the 4wd it too is a wide angle view. Works fine though when cars catch up quickly, as they do when towing, the cars tend to appear out of nowhere. Still very useful though and there are no visual issues for the driver with the screen showing all the time. Stereo and nav functions work in parallel but we do have to scroll through menus to get the various screens. You would need to confirm if it is just a 12V signal to the factory head unit to trigger the camera screen, based on that video I suspect that is the case and not some weird canbus magic. Would guess you would need to isolate the camera to get the head unit back.
