GR Yaris Alignment, Camber and handling related talks
With OE suspension layout, Rear camber changes as you adjust toe unfortunately. The only way to allow independent rear camber adjustment from the toe adjustment, is to replace the top arms by adjustable ones, or use specific camber bolts which are cheaper and quicker to adjust the rear camber.
Yeah but I was hoping some degree of adjustability would be possible on the rear...somehow.
I'll run this setup for a couple of months and if I'm not convinced I'll fit two 90105-17015 bolts on each corner to get even more camber front.
Reactions: micsub
It seems to be quite random though, with similar toe and bolt I have -2°27' front and -2.0° rear, quite symmetrical...
Reactions: micsub
YEs it is quite random one car to the other. Fronts I have camber adjustment possibility with the Tractive suspension, so I can do what I want, (I like it @ -2.5°) but on the rear with OE arms and all I didn't have the same camber on each side. Only solution was to install the Proflex camber bolts to be able to adjust camber at -2° on both sides.
Reactions: Yohz78
Guess I've been Lucky then... I have -1° 59' rear left and -2°01' rear right
Reactions: micsub
I think I'm going to spend a bit more and get some DNA adjustable top mounts for the stock suspension instead of f*#@ng around with camber bolts.
Any recommendations to adjust the rear suspension? Something more serious and "definitive" than camber bolts if possible.
Reactions: micsub and Sekred
Hardrace make a Camber Arm.
Here is where I'm at (left) right now. I experimented again with rear toe out after having the suspension done thinking removing a lot of the roll and stiffening it up would make that behaviour more predictable and controllable but I was wrong.
I also have whiteline rear bolts but couldn't get more rear camber - both people tried. Only added .3 for me - must be the lowering.
Oh this is just one bottom camber bolt up front. Less chance of it moving. The rest is from the DNA top mounts including the improved caster adding over 1 degree to total 7 degree.
Did the rear toe in help with stability under heavy braking? As I currently have very similar specs to you. But more camber and neutral toe at rear. And I think I’ll go minor toe in. The rear feels like it wants to dance under brake and lift off oversteer
Reactions: Jones86 and micsub
I had toe in at the front and toe out at the rear and it was too skittish under brakes and general turn in. Same toe in front and rear and it is far more stable. Was manageable at the track but was sketchy on the road and could easily catch you out if an animal jumped onto the road etc.
Reactions: micsub
Hi @ll,
had destroyed the inner edges of my PS4s Fronts so put on Pirelli PZ5 all around and had an alignment today...
The car is bone stock and they have taken the wrong car in the software (mine is a circuit pack and has Brake Ducts), anyway no special camber bolts etc. used for the alignment results.
I wanted max possible camber front & rear and median toe in front an rear.
So what do the pros think? Okeyisch result or should I take another shot to fix the camber L R difference at the Front? If so which Toyota Camber Bolt combination should I use at Front Left to match the nearly -2 degree Camber at Front Right?
And last question: what about the 0*10' L & R toe in at the Rear? Should I let them reduce it a little (maybe to 0*05') because of outer tire wear or is it ok?
Thanks a lot for your help.
Regards
You have no need to do anything.
1degree59minutes is just 0,118 degree's less then 2dg06minutes. I think the car will settle just about that amount when you enter the seat.
Reactions: CrUzO
Thanks a lot for your answer GottGry. I thought similar about the Rear Camber.
what do you think about the Camber difference L & R at the Front and the total toe in of 0*20' at the rear?
If you want max camber with bolts just buy some adjustable camber bolts (e.g. Whiteline etc) and you'll get -3 degrees and the mechanic can adjust L&R to be very similar.
Reactions: GottGry
Thanks a lot guys! I think in relation with the front max camber I have expressed myself in a way. I've meant: I've wanted max possible camber with the standard bolts.
The technician said, they couldn't match the Front Right Camber with the Front Left and if I want them to do so we need a original Toyota Camber Bolt with a different setting. At this point my question is: which original camber bolts should I buy to be able to set a balanced camber at the Front? I don't need more than 2*00' camber at the front and I'm already happy with the 1*53' at the Front Right, but I'm not so happy with the 1*32' at the Front Left and need help to find the right bolt combo to match the Front Right setting 🤔
Additionally I'd be very happy with suggestions about the toe in total at the Rear in relation of a balanced setting for good turn in / rear end stability and tire wear 😅
