I understood the practical steps as: inspect intake manifold and borescope. If you have blow by already, you will see oil in the intake and your cylinder wall cross hatches are likely worn. A catch can and high ethanol fuel are the band aids to prevent detonation. The solution is to rehone and re ring pistons. Or go aftermarket.
