- Dec 27, 2021
- 1,778
- 2,952
Yeah, I found when I got the wheel width/offset optimised and the wheels were further out, that makes the factory ride height look too high.I suspect i should probably go straight to a good set of coilovers, but i'm tempted to swap to lowering springs first also...
My TEs are on the car now, and it definitely needs some lowering. It looks like a monster truck with the fitment and ride height atm
This is 18x9.5 ET38 TE37 Saga S-Plus with 255/35/18 Potenza Evos - i think i would have preferred a little less poke tbh, probably ET40 or higher would be better.
With the standard wheels and no spacers the fact that the wheels were more recessed hid the full extent of the gap between them and the arch when viewed from normal eye height.
