I just got the tein rx1 installed now waiting for my white line camber arm to come in. These coilovers are really nice I want to say they’re more comfortable than oem while giving better steering response with dampening set in the middle. What size sway bars are you running right now?I run Whiteline ones. Wait for when they have offers.
I recommend you install coilovers and camber adjustment before Anti roll bars.
Lol... Looks like you carbon copied my mods!I just got the tein rx1 installed now waiting for my white line camber arm to come in. These coilovers are really nice I want to say they’re more comfortable than oem while giving better steering response with dampening set in the middle. What size sway bars are you running right now?
That’s pretty funny! After spending some time with these I notice a very quiet clicking when at low speed. I was wondering if you have this as well? They do drive very nicely thoughLol... Looks like you carbon copied my mods!
I've got rx1 and Camber arms and sways!
RX1 are lovely for road but not good enough for track. Hence I fitted sways... However, even after fitting, suspension still feels lacking on track if you are using sticky tyres.
Cant remember the exact size but it was the smaller of the 2 sizes available.
could be the drop links coming loose. The threaded part is too short. Add some washers (to bring it out 3-4mm) to it before using the nut. Use some thread lock too. Mine constantly came loose at the front before I added washers and threadlock.That’s pretty funny! After spending some time with these I notice a very quiet clicking when at low speed. I was wondering if you have this as well? They do drive very nicely though
I do have washers on them I did notice the nut it came with was weaker than oem. It could be the pillow ball joint to if I had to guesscould be the drop links coming loose. The threaded part is too short. Add some washers (to bring it out 3-4mm) to it before using the nut. Use some thread lock too. Mine constantly came loose at the front before I added washers and threadlock.
did you use a single washer or pack them out? I added washers above what Whiteline said to use.I do have washers on them I did notice the nut it came with was weaker than oem. It could be the pillow ball joint to if I had to guess
