please share a youtube clip or 2 to share with some fast laps when you are driving the GR Yaris? I really need some more inspiration before going back to the ringwe've run comfortable 7:50 BTG laps of the Nurburgring *with* traffic to ....virtual best around 7:40 .....the car definitely has 7:3x laps in it no problem with some more committed driving from me .....much quicker again with a pro behind the wheel
Sorry, this is nonsense.Okay, so this is my option.
The bolt is smaller in Dia because it is off-set meaning the torque is significantly lower the OEM bolt. Because the torque is lower, the clamping force is lower.
To state the obvious, because the clamping force is lower the joint may move under load.
This is reason I would not use them myself.
Disagree completely actually with your explanation. It's illogical what you're saying.Sorry, this is nonsense.
A waisted bolt, which adjustable camber bolts are an example of, will actually have better clamping reliability than a conventional bolt for a given torque as the bolt stretch will be greater due to the reduced cross section of the waisted part.
Torque is only a way of applying load to the bolt and needs to overcome the friction of the thread and seating face, and that's it. You apply the recommended torque regardless.
As both of these friction factors are the same in this application whether the bolt is conventional or waisted, the absolute load applied will be the same but the additional elastic stretch of the waisted bolt will mean that it is better able to withstand loss of tension due to vibration, heat cycling etc.
The difference on such a short bolt under low load will be marginal, but it is undeniable.
Source: Worked in industrial bolting for many years![]()
OK. This isn’t something I’ve just invented in my head thoughDisagree completely actually with your explanation. It's illogical what you're saying.
Fully qualified Mech in 1983 plus many post trade training courses including failure analysis.
What you're trying to say is that reducing bolt diameter and torque won't reduce clamping force, that's BS.
that's interesting.. do the (thinner neck) camber bolts from Toyota have a lower torque setting than the regular/standard OEM??Ok.
So going a bit further.
Typically, the torque on these types of chamber bolts for the GRY are about 125lbs/ft verse about 200 for the OEM bolt.
Can you see my reasoning here?![]()
I ask a question then; what actually matters? The torque applied, or the pre-load left in the fastener?Ok.
Force. What's the force?I ask a question then; what actually matters? The torque applied, or the pre-load left in the fastener?
Have not seen a difference in the spec but it's a fair question.that's interesting.. do the (thinner neck) camber bolts from Toyota have a lower torque setting than the regular/standard OEM??
(from a quick search on the webs, the front struts pinch standard bolts seems to be at 200 lbs.ft - ca. 270 N.m as you pointed out)
