GR Yaris Front End Alignment moving on circuit
SuperHoon
Fascinated Member
Hello Yaris enthusiasts.
I have been having issues with the front end of my yaris when in a track situation or heavy pothole while turning, the straight ahead position of the steering wheel is moving to one side. i dont believe it to be at the wheel end as the car still drives straight with my hands off the wheel, the wheel is just in a different position.
its as if either the steering rack is moving on the subframe or the front subframe is moving on the body. i have checked and rechecked all the bolt tensions on the rack, subframe, front suspension etc but it continues to move around. When it moves i can hear a bang sound and change in steering wheel position which is pretty concerning.
theres a few parts available in the aftermarket such as the spoon rigid collars, hardrace steering rack braces etc but i would really like to know who else has had a similar issue and what actually fixed it. i think there are many suppliers saying "yes this will fix it, buy my parts" but obviously they have a vested interest in making a sale.
Has this happened to you? how did you fix it?
my car is a basic "track pack" with 265 re71rs, coilovers with big springs, whiteline anti lift kit, a cusco 1.5 way rear diff and whiteline rear ARB.
They're from australian supplier Shockworks.
Camber adjustment is via the top bolt of the suspension upright and damper lower mount, its not exactly like a camber bolt as the bolt head has an offset flange that locates in the lower mount. it seems a bit more stable than a traditional camber bolt. the top mount is still the factory item.
the circuit i was driving yesterday is probably classed as extreme as far as elevation change and road camber goes. the previous circuit i visited was flat and didnt appear to have issues of the same magnitude but still felt a little off.
with OEM dampers and lowering springs this issue wasn't found with the same wheel and tyre, but firmer springs are assisting the car to generate more lateral load.
use paint and check what is moving, and then enforce those areas. Could be subframe? easy to at least mark camber and toe etc.
Anecdotal evidence from other users in hillclimbs (noted you said the track was more extreme, with elevation changes) is a feeling of the steering feeling off centre.
If the car is stationary and on the ground, pop the bonnet, turn the wheels, you can see the OEM rubber top mount moving. With the DNA top mount it doesn’t. I wonder if this is something that you’re feeling? Otherwise, with the loads generated by much wider tyres, I’d consider strengthening the front sub frame.
We had a similar thing with a customer car on camber bolts.
Changed to new bolts and never had the issues again.
Maybe just was a flaw with these bolts.
Which camber bolts, or which manufacturer were they from? What are you using now?
Hard race do some strengthening braces for the steering rack here which might help.
Dont really think its a steering rack
yeah it sounds more substantial than that, i dont think it would be the damper to upright bolts.
im expecting it to be the front subframe moving on the body. from memory the bolts only clamp the subframe to the body there's not really any 'positive' locating lugs or similar on there.
Revolution has some nice TI parts to stiffen the rear and front members.
could be one resolution if its the subframe.
