GR Yaris Caliper Pins
Is this the correct part for the front caliber pins?
Looks like it. Matches the part number on the list.
Im planning to replace brake pads this weekend…are you making a video?? Aware there are how to guides already but anything to watch for? Have also ordered some specific grease and brake cleaner while I’m at it. My only worry is not being able to push the pistons back I think.
Its very easy but recommend you have metal brush to clean any dust residuals (though not likely an issue with stock pads).
Also you should have brake piston separator tool to have cylinders opened prio removing or installing new pads just to avoid possible damage to seals.
Othervise its 5-10min job per corner.
Thanks v much. I’ll look out for a tool just in case as I don’t fancy getting stuck halfway through. I keep accumulating specialist bits and pieces for just one job, but I suppose in the long run it will pay itself back in saved labour etc if its Simple stuff!
they're quite handy so tool pays itself easily when you get into first problem of stuck/tight piston.
Or you can use the time-honoured ghetto method of just easing them back using the old pads and a couple of screwdrivers? :D
Funnily enough I used to do that with my mountain bike when I was younger. It was usually fine with the old pads left in as a lever, but in my hamfistedness I once managed to damage the edge of the piston when the screwdriver slipped. Not wanting to make that mistake on a more expensive car!
Ouch. I avoid that by using the pad to push back the piston(s), acting off the disc or caliper.
