GR Yaris Rear bumper rattle
Istiban
Devoted member
If you grab the rear bumper at the bottom edge approx. middle it makes a horrible rattly sound.
Does anyone else have this?
Both the rear wheel arch pins are in although don't feel like they are clamping anything too tight. Any solutions out there?
Istiban
Have a look in the wheelhouse, behind the rear-wheel you'll see a plastic "screw" that you can turn with your fingers. That tightens the rear bumper :)
which one? or a photo?
So that actually worked to a degree - thanks. Those plastic wing nuts are sh1t please tell me that that was some Kaizen engineers idea of weight saving...So I'm guessing these are single use as they simply don't tighten down. Anyone tried actual nuts on there?
The main issue is the two at the back, the plastic brackets have stretched and the push pins just slide around not sure new pins are going to fix it, i might try some washers see if that helps tighten everything up.
Istiban
Istiban
Good! Yes lets pretend its a rally product :)
I need to tighten those once in a while, also asked at Toyota but it is what it is..
By way of a quick update, changing to nuts to replace the non-threaded plastic fasteners on inner wheel arch and nut's bolts and washers on the bottom where the diffuser connects the the bumper bracket - fixes the rattle.
Istiban
