GR Yaris The 17" Fitment Thread - what fits?
Sam
Hopefully this thread doesn't count as a repost of the Wheels thread, since this is a distinct question vs the Show us your aftermarket wheels. thread.
What 17" wheels fit?
What works for you?
Post pics!
here is also some info
Reactions: Sam
Just got my second set of Braids, now 8" wide. What I like most is that they are (the only in 17" sizes?) flow formed and also have a name of being very strong. And they have very good caliper clearance for a 17" (test fitted 8" wide also).
Further initial impressions copies from other thread
- Like the looks, 8"wide rim has a deeper center part compared to my 7" wides
- weight 9,6kg. Was a little apprehensive about going up a kg. But keeping in mind the formula for rotational inertia where radius counts double and assuming the weight difference worst case is in the barrel, this (square of 18"/17") lands us in an unchanged/insignificant change in rotational inertia vs OEM BBS. So all good. Tyre choice a much bigger factor...
Really nice.
What ET are these?
Et45. They are machined to fit with correct centre hub and et to your liking...
You had tyres fitted to these yet? Tell the fitter to watch out for some radial run out. on them.. I bought a set of braids and 3 ou of the 4 had some radial run out, 2 of them minimal but one of them was 3-4mm.
If correct that is a LOT. That would mean high speed vibrations. Axial less problematic. Were they properly fitted to the balancing machine?
No tyres fitted yet....
Yeah, I even came and looked at the fitters machine and remounted the wheel myself! I have a video showing the run-out somewhere.
Also Michael Knight had issues with Braid:
Michael Knight said:
Got the Braids installed. ET35 17x7J. More space between wheel and brake saddle than with ProTrack One 17x9J ET45.
One wheel is not straight (center hub is rocking) - asked from reseller and Braid what to do.
Just be warned.. Im going to get some Cinel Truismos for next winter.
Yeah the Turismos apparently fit too, haven't seen them on a car yet. Nice wheel.
Just be warned..
Thanks. I have a pretty good reseller, I'm pretty sure he'll do all to help in case there is an actual issue. Still good to know this is a functional motorsport wheel, not 'jewellery' wheel like many 'nice' in effect are. Just to say, as long as it's not scraping or affecting driving/mechanical, I'm not too fussed.
Look forward to seeing them on your car! Fingers crossed you have a perfect set.
There is of course the new OZ Superturismo TGR-WRT where there is a 7,5x17". The name suggest it should fit a GR Yaris but not 100% confirmed yet.
Tyre fitted commented they were straight. Maybe one had very faint axial runout visible by eye, but nothing probelmatic.
Looking forward to pics
