GR86 Condensation/ moisture in boot
BanjoGazooey
West Sussex
Ive always felt like my GR86 has a bit of a condensation issue.
Dehumidifier bags have been relatively effective but I noticed recently that my boot floor under the foam bit has had a little bit water pooling in it. I dried it out but always seem kind of damp.
I'm still trying to pin down where it's coming from but I was wondering if anyone else had noticed the same?
👀 Will look
Didn't the GT86 have issues with not sealing around the rear lights?
Given this recent thread about the seating/fitment of the lights on the GR, perhaps worth looking at.
It would need quite a lot of condensation to result in pooling.
Do you turn off your AC? It's as much help for drying the air, as for cooling it. If there's condensation building up inside the car because of the time of year, I guess you could get enough or small puddling to form.
Yes, it did, the gaskets would fail, but it would take a couple of years to happen. Or, people would overtighten the bolts securing the lights causing the gaskets to not seat properly. I do hope it's not that; I hope the change in tail light design might have solved that issue. I know that the clusters are no longer secured by bolts from the inside, so hopefully the only entry point into the car will be the wiring loom which should be easier to seal.
Hmm I do tend to run without it most of the time to leave every last HP for the wheels. Will try leaving it on and see how much difference that makes.
I doubt very much you'll notice it sapping much power. Besides, I believe the first gen would actually disengage the AC clutch when the throttle was wide open; would assume the GR does the same.
If you don't have it on often, then perhaps the air is just damp and the condensation is just starting to pool up. Especially this time of year if you're getting in the car with wet clothes, etc. I'd suggest dry it out as best you can and then run with the AC on from now on, even when it's cold. I never turn mine off and only get condensation on the very coldest days, even though the car is driven infrequently.
Checked mine and bone dry, AC not on all the time, used as and when. I do get condensation on the windscreen, usually after I have parked up and it is warm inside but cold/damp outside.
Scraping ice off the inside of the window at 7am is never fun, I need to up the dehumidifier bag count.
I imagine not! I use a 1Kg ‘Hillington’ bag behind each of the seats, 2x ‘Pingi’ 350g on the dashboard and a single 350g bag on the rear seat centre console. In this weather they need a recharge more frequently….
yeah maybe I just need to up my AC / dehumidifier game. Will double check it's not a leak next time I get the pressure washer out though
Interesting, sort of. It would make sense, especially if it cut out at high rpm to protect the compressor. I leave the ac on all the time, it makes demisting the screen way easier.
As conscript says the AC compressor clutch disengages at full throttle.
