GR Yaris Short shifters
I've updated the models (is the V2), I could not make it fit on the measures you sent with the new sketch, so I more or less adapted the old one to this new one. I'll send it to print, and on next month when CAE arrives I'll fine tune it manually and upload a proper v3.
Thanks a lot for your help and sharing
I have an in-between solution, TGR Shift Risers and a Foresight short shifter linkage. This raises the shifter by 25mm and reduces the fore/aft throw.
I plan to move to a CAE shifter later down the track if this is not sufficient, and now that there is a "plate" to cover the hole I am even more inclined.
Looks like a good cheap solution. Pls report. The ultrashifter seems to be great but is a little bit too extreme for me
The print is here (Don't judge the keyboard state, it's a "work place" one :ROFLMAO:):
This has been done in high resolution PLA to have a good template to mark the Carbon Fibre (Just in case is accurate as is), and I've ordered a 1mm thick in PETG to be able to do the test fit and do all modifications needed in case it needs modifications.
As I told you, need to wait until next month to order the shifter, so still some weeks left for the final version.
Thanks a lot for youe help in getting this thing done for all of us!
Well what I like more about the CAE is the fine tuning of the postition in the gates, I never liked this "Auto setup" things because measures change some mm from car to car... (The height should be good and the short throw is superb too, but the engagement is the best for me).
yes, this part :
and this :
can be a good cheap solution ;)
Maybe you can add my 35mm shift knob extension to that, will make a new thread soon inquiring for interest.
I think it is necessary to enlarge in this place (look well on the V2 communicated)
Yeah, I've seen it in a different shape/measure/orientation, I tried to make the V2 match the 5cm scale, but everything was getting out of alignment, so I made the modifications as best as I could, and I'll fine tune with the 1mm one and release the "V3" which will be fully tested.
Thanks for your help and effort man!
Could be an idea, although the reason (apart from price) I went this way first was to maintain an OEM+ look, but now I have shifted from the neutral looking Recaro Pole Positions to the OMP HTE-R rally seat with halo and all...the CAE is looking more and more tempting :LOL:
Same here, also with the extension it looks OEM, passengers just assume this is how it came from factory...
with shift risers
Without shift risers
A Masterpiece.
Put it up for sale and you make money here. I would buy it immediately :).
A Masterpiece.
Hahahaha, thanks, but It involved cutting the original trim and “pasting” a CF part with the original part used as a template:
I need to finish trimming the glue on the top edges, but is looking good 😊
I would even buy the original part so you can build it like this :).
It has no major difficulty. The original piece is completely straight so, it’s a matter of cutting the same piece you took out in a different matherial and using a good glue for PP to put it back
