GR Yaris Hello there
Installed a larger oil cooler. Previous was Setrab1 25 row, now its series6 25row so twice the cooling capacity.
Installed it sideways as this way there was more space + managed to use old oil lines.
Did the test run in -20'C. Oils didn't go above 75'C in normal drive. need to test also on ice track to get better feel.
Maybe not the optimal for cold winter days but feel this might be nice for summer track driving.
It also adds +0.8ltr of oil system capacity (0.52ltr from cooler and rest from the oil lines) that also helps to work with extra heat.
It also adds 0.6ltr of oil system capacity (0.52ltr from cooler and rest from the oil lines) that also helps to work with extra heat.
Like that a lot.
put maybe 4.6 ltr of oil yesterday.
Had hard time reading the oil dip gauge (I frankly hate it) so checked again this morning. it was little under full so added extra 0.5ltr oil.
Also added a 50% lower front guard to get some chill protection - let's see how it heats up now.
with new install the cooler comes nicely behind the right fog light opening. Good in terms of cooling but need to add protective mesh.
found a good mesh option. resembles a bit of the original plastic cover.
Tested on short semi-spirited drive on smaller road, -3'C ambient. Oil temps now got to 90'C and on constant highway they seem to be around 85'C. looks good so far.
if anyone is interested can sell the series1 25 row for 100€ (including cooler mount) - paid 170€.
in addition sandwitch plate is needed (with thermostat) + needed lines + fittings. I have 1.5m brand new PTFE-line (AN10, stainless steel braided) as I managed to use old lines instead of building one new line.
Reactions: Els
20cm of slush and TRD undertray did not go so well together so ordered a Hardrace metal under tray for winter. need to see if try to get that revised GRMN undertray for summer or not. Is that available via JPN with correct P/N?
is it difficult to order via Easycars JPN to EU? no experience there.
Got the hardrace alu belly pan and am positively surprised - for the hobby rallying it is surely sturdy enough with 3mm thickness. Maybe not one to run full monty rally stages, but for light weight rally fun it surely is better than stock paper one.
maybe with little mods it could be even converted to be more sturdy for more serious fun, if for instance additional brace would be added in between the frame towers etc.
Installed the hard race undercover pan today.
Installation required enlargening four holes to M6 in subframe so did that yesterday, with additional paint. Let it dry over night.
Installed the rivets + pan today.
Getting the stainless rivets properly installed was harder than expected, so it might be good idea to let a pro shop do the installation. I do have rivet pliers but IMHO they do not work well with those big M6 rivets.
Managed to get the pan installed and quite happy with how it fits. I do have DNA subframe stiffening mount that makes the pan protection to sit few cm lower than with stock but I don't think it will be any issue.
Initially I planned to get a lightweight GRMN pan for summer use but now not sure if bother doing it. This weighs more but then again provides more protection so more hassle free miles on gravel roads (which I think is the most fun). Car is more for smiles instead of measuring lap times for 0.1s improvement.
I can recommend an impact driver to get those rivnuts to settle without issue with the counterhold tool provided. Hand rivnut tool is difficult to get enough clamping force and if using hand tools the rivet just rotates along and won't settle.
Since the Hardrace skidplate is made out of aluminium it should have quite a good thermal conductivity especially compared to the isolating 'paper' OE undertray, so I wouldn't be suprised if it manages to extract quite some heat by absorbing radiation heat (being black too) and getting rid of it by the convecting airflow under the car.
I wonder about that too... specially about cooling/airflow around the transfer-case box.
yes, and in addition its more open from behind the engine as stock tray so providing better flow. Maybe not the best solution for +200km/h driving but I'm usually between 60-130km/h so not really a biggie.
Have been tinkering of this new model arriving. With all its nice features, I feel it is maybe irrelevant in my use case to get a revised model.
I have already done all the needed upgrades (excluding suspension & exhaust) that I would like so it doesn't bring anything new on the table as such.
Not needing any more power, not needing any more nannies nagging of my driving, so quite satisfy with the old lady how she performs.
If any I'd like to get an improved suspension (for rally driving), with extra travel and maybe improved suspension in general.
Also thinking of getting little bit uprated exhaust to improve exhaust flow.
The only feature I don't like is the failing power steering in fast driving but that luckily happens only in loaded front scenario on track. So it is there only in certain corners, and does not really affect overall performance. Just good to know its there.
Would like to learn to set up car in general at home garage. In terms of changing ride height, alignment, and suspension, between different driving scenarios (rally/loose vs Track).
Just in terms of technical setup + how does it affect driving.
Ordered a set of 215/45/17
VALINO GREEVA 08D TW360​
for summer every day tires. 440€ delivered to door - price is ok.
Joys of modified cars. The new belly pan was rubbing to my oil pickup lines to the cooler and caused terrible resonation so had to use 2x chassis shims to drop pan 6mm from front. Oh well. Now it works nicely.
