Combination of Ravenol and Millers for me for the driveline oils, don't forget the drain plug washers will need changing too;
90080-43037 Engine oil drain plug washer
12157-10010 Rear Differential drain plug washer
12157-10010 Transfer box drain plug washer
90430-18008 Gearbox drain plug washer
Things like fuel filter and spark plugs should be done every four years by the book, but realistically every two or three will suit most of us.
Prop shaft bolts should be checked every year.
For those running the stock air filter, then that's once every couple of years.
...and of course brake fluid should be every two years at least, I think I've done mine twice in three years. Motul RBF 660 over the Toyota reccommended IMO.
It's all very dependent on your usage and how hard you drive the car...I know mine is completely out of sync with the scheduled service requirements, but everything is 'ahead' of schedule in that regard. I've refused to buy a service plan on any vehicle for years now, so I tend to keep a checklist handy and tick things off as and when.
For those worried about warranty as long as you keep receipts that show the quality of the parts you've used, you can use any garage you want or even do some of the maintenance yourself (if you have access equipment etc). It certainly beats going to some of the Toyota dealerships and getting some complete monkey working your car and filling it with the wrong fluids!
