There is a thread for Detailing where I was asking similar question last year.I usually use microfibre cloths. Does anyone use air blowers / leaf blowers to dry their cars?
Any recomendations?
Hmm, interesting. Are you filtering the rainwater somehow?Being in a hard water area, I always use rainwater which leaves no water spots and avoids the need to dry the car afterwards.
How long has your resin lasted out of interested? Since our water is basically chalk.I have a Raceglaze water filter and it's fantastic. Use it to filter the water for the final open-hose rinse, then walk away. No water spots at all.
I have recently purchase a nice, soft drying towel for doing the glass and mopping up water that sits on the horizontal panels, but it's really not needed with a the filter. Last year, even in direct sunlight, I just left the car to dry naturally and there wasn't a hint of water spotting.
No, it comes straight out of the water butt, crystal clear.Hmm, interesting. Are you filtering the rainwater somehow?
I think the first change I did was after about 10-11 months or so, but I was using it quite often. I'm trying to use it more sparingly now, wash the whole car, rinse it down with a pressure washer, then hook up the filter just to do a final rinse with an open hose. But the resin isn't all that expensive.How long has your resin lasted out of interested? Since our water is basically chalk.
See, if my car sits out in the rain and then dries, it often leaves water spots, even on a freshly washed car. I thought therefore that even rainwater would need some filtering.Rain water, falls from the sky, it's free, hook the k2 pressure washer to water butt, happy days, no water spots even on the hottest days![]()
Honestly it's the best thing I've bought for car washing; I always hated drying, it was the most tedious part of the wash and felt like the bit where you're likely to introduce the most paint wear, so being able to cut it out entirely was a Godsend.
It will be pretty good but obviously not as good as water that's gone through a bed of ion exchange resin. Rain water is pure, but pick up pollutants on its way down, through your gutters into a water butt, granted its not going to be full of hard minerals.See, if my car sits out in the rain and then dries, it often leaves water spots, even on a freshly washed car. I thought therefore that even rainwater would need some filtering.
7 litre.Which size? I'm looking at the 7 litre one right now...
7 litre.
If you want to reduce the steps even further, you could just pressure wash directly from the Raceglaze, although they advise you install the little filter they supply. So apply the foam, let it dwell, then plug in the PW directly into the Raceglaze and rinse off. It wont be as good as a contact wash, but it's great for getting the worst off in winter, and because you don't really have to dry with a towel, you don't have to worry about dragging anything that's left over the paint.Great! Orderer one now, excited to test this out! Will be nice during winter, I can foam wash off the worst of the salt and crap, rinse with this, and then blow most of the water off with my leaf blower without having get everything off.
That's just airborne dust and muck sitting on the beads on your paint. Water dries and leaves the muck behind.See, if my car sits out in the rain and then dries, it often leaves water spots, even on a freshly washed car. I thought therefore that even rainwater would need some filtering.
