GR86 Drying
Steve O
Devoted member
I usually use microfibre cloths. Does anyone use air blowers / leaf blowers to dry their cars?
Any recomendations?
I have a Raceglaze water filter and it's fantastic. Use it to filter the water for the final open-hose rinse, then walk away. No water spots at all.
I have recently purchase a nice, soft drying towel for doing the glass and mopping up water that sits on the horizontal panels, but it's really not needed with a the filter. Last year, even in direct sunlight, I just left the car to dry naturally and there wasn't a hint of water spotting.
I've got a Bigboi BlowR Pro touchless car air dryer that I'll sometimes use to get the water out of crevices but, it's far too powerful to be used anywhere near PPF edges (I found this out the hard way when I first used the dryer; I got too close and it lifted an edge which allowed dirt etc to get underneath. Had to get the detailer to sort it). Best method I found was to blow the water into a drying towel, otherwise I just ended up chasing water around the car. Although I've got literally hundreds of MF towels, I'm going to get myself a Raceglaze water filter as recommended by @Conscript - with our super-soft water up here I reckon the resin should probably last me the life of the car!
Any recomendations?
There is a thread for Detailing where I was asking similar question last year.
tl;dr I didn't listen and didn't buy the water filter, instead using my low powered blower to dry the car.
Now I would probably do what Conscript is recommending and go with the water filter. I found that no matter how much I tried the air blowing would still leave some water on the car, or worse, cause it to evaporate, leaving the minerals (we have very hard water here) behind. It was actually my detailer/PPF installer who pointed it out to me, as the residue was sometimes too hard to spot.
Not to mention the batteries on the blower run out so quick 😅
Being in a hard water area, I always use rainwater which leaves no water spots and avoids the need to dry the car afterwards.
Hmm, interesting. Are you filtering the rainwater somehow?
How long has your resin lasted out of interested? Since our water is basically chalk.
Rain water, falls from the sky, it's free, hook the k2 pressure washer to water butt, happy days, no water spots even on the hottest days 👍
yeh i have the bigboi mini . Very good if you want to do the wheels, roof , windscreen and between panels etc but if you plan to do the full car then probs need the next model up. When you get to the panels by the time you have done one panel/section it has blown the water someone else as it isnt powerful enough to blow it off the car so then need to start using a cloth but if you have the time it is possible to do the whole car.
Also be warned even the mini is loud so if you don't have a garage , expect neighbours to look and get annoyed after a while.
I think the first change I did was after about 10-11 months or so, but I was using it quite often. I'm trying to use it more sparingly now, wash the whole car, rinse it down with a pressure washer, then hook up the filter just to do a final rinse with an open hose. But the resin isn't all that expensive.
Honestly it's the best thing I've bought for car washing; I always hated drying, it was the most tedious part of the wash and felt like the bit where you're likely to introduce the most paint wear, so being able to cut it out entirely was a Godsend.
See, if my car sits out in the rain and then dries, it often leaves water spots, even on a freshly washed car. I thought therefore that even rainwater would need some filtering.
Which size? I'm looking at the 7 litre one right now...
It will be pretty good but obviously not as good as water that's gone through a bed of ion exchange resin. Rain water is pure, but pick up pollutants on its way down, through your gutters into a water butt, granted its not going to be full of hard minerals.
I tested the water at home and it was 630µs/cm, which is very hard, rain water in a bucket was 400µs/cm, could be lower if it was cleaner and didn't have leaves in it, but that's how you would expect to find it. Seawater is about 50,000µs/cm and water that's gone through Ion exchange can be as low as 0.01µs/cm.
Great! Ordered one now, excited to test this out! Will be nice during winter, I can foam wash off the worst of the salt and crap, rinse with this, and then blow most of the water off with my leaf blower without having to get everything off.
Great! Orderer one now, excited to test this out! Will be nice during winter, I can foam wash off the worst of the salt and crap, rinse with this, and then blow most of the water off with my leaf blower without having get everything off.
If you want to reduce the steps even further, you could just pressure wash directly from the Raceglaze, although they advise you install the little filter they supply. So apply the foam, let it dwell, then plug in the PW directly into the Raceglaze and rinse off. It wont be as good as a contact wash, but it's great for getting the worst off in winter, and because you don't really have to dry with a towel, you don't have to worry about dragging anything that's left over the paint.
That's just airborne dust and muck sitting on the beads on your paint. Water dries and leaves the muck behind.
I'm very lucky listening to you all, our water is so soft I never have to descale a kettle and at a push I can leave the car to air dry.
I use a pet dryer. Takes some time but I've always found it fine. Have one edge of PPF that lifted slightly but wasn't down to this. Bottom of the wings get battered with dirt over time. After Winter I'll probably pay my detailer to give it a wash and decontamination as I'm using it daily now as a reset.
Before I purchased a water / DI filter I was going to get one of the Big Boi Blowers, however the inital purchase price was higher that a water filter so I decided to go for the cheaper option and see how I got on. I'd 100% recommend a water filter, it probably my favourite every car cleaning purchase.
However I do have a IT Dusters CompuClean Xpert (https://www.itdusters.com/product/xpert/), which I have tried on the car and its ok but it doesn't have enough power for the larger surfaces. It works best for drying wheels, removing water from behind the mirror, boot jams, etc.
My main issue with it though is the power cord, as is quite short at about 1.5m. Now I'm aware it not meant for cleaning a car and for the little jobs its fine. I also find this (the cord) can get in the way and ends up wet from being dragged across the rinse water, I suspect I'll have the same problems with dealing with a large hoze from a proper blower.
If I was going to purchase a blower for car drying, I actually get a cordless leaf blower. I was initallly against this idea due to dirt particles and them not having a filter. But realistically the air isn't that dirty where I wash my car, and it won't be sucking up ground dirt as it'll be used at waist height or higher most of the time. If I was to purchase one I'd go with the Milwaukee blower, however this is because I've already got Milwaukee tools/batteries, and I'd source a stubby nozel for it: https://stubbynozzles.com/products/...l-single-battery-leaf-blowers-2724-20-2728-20
