Abbey Toyota Redhill
lee1563
Zookeeper
Staff member
Big shout out for these guys. Just had the first service and recall carried out and they could not have been more accommodating, also why I waited!
Yeh I went there in October to have all the driveline oils changed, very good 👍🏻
About to head down to meet them this afternoon. Did they know what specialist oils were required for the GR and able to supply them? Only about 2k miles in but after one track day and one Drive Limits day l think l might get all the oils changed just to be on the safe side.
I've only ever supplied my own oils in both visits, just ask them they seem pretty competent.
Thanks. I don't suppose you have a handy list of what oils you supplied and where you sourced them from? There seems to be a wealth of info on oils in the forum, but wading through all the discussion to find the optimum combination is a bit challenging.
08880-83886 Engine Oil, 5L - £50 (TOYOTA ONLINE), although I use Millers (bought from Fensport, usually)
https://www.fensport.co.uk/collecti...with-nano-tec-0w20-api-sp-ilsac-gf-6a-5-litre
08885-81001 Gearbox (LV), 3L - £60 (TOYOTA ONLINE)
08885-81060 Transfer box (LT), 1L - £20
08885-81070 Rear differential (LX), 1L - £20
90915-YZZM3 Engine Oil Filter - £10 (TOYOTA ONLINE)
90080-43037 Engine oil drain plug washer (TOYOTA ONLINE)
12157-10010 Rear Differential drain plug washer (TOYOTA ONLINE)
12157-10010 Transfer box drain plug washer (TOYOTA ONLINE)
90430-18008 Gearbox drain plug washer
Great to hear that this repair centre is up to the job as they are about seven miles from me. I think my GR86 will be going there for servicing, when I get it..
I went to see them this afternoon and met with David. A very reassuring chat and he clearly 'gets' that the GR is not your average Toyota. I have booked mine in for a full oil change early in the New Year
They are happy if you supply your own oil as long as it meets the Toyota oil spec or higher. I used this.
Booked in for the beginning of March for my 2 year sevice and recall.
