Nope. Last car didn't either.
Edit: if it bothers you, a possible solution...behind the glovebox is a 12v socket. Put a USB adapter in there and then buy one of those little LED desk lamps, the kind which are designed to be plugged into a laptop. I'm sure I've seen them on an adjustable flex so you can bend them into a fixed position. Position it so it shines downward into the glovebox and voilà....glovebox light.
Or, do the same thing using one of those little LED strips you can buy. Again, stick it somewhere above the glovebox.
Only problem is I doubt there's one that's motion activated so it will be on all the time. But that socket is ignition switched so it will go off with the car and wont drain battery.
