GR Yaris Theory - Is the Fuel Gauge for the Elderly
GWAD
I'm beginning to feel like the petrol gauge is designed for the stereotypical Yaris driver. Coming on with about 50miles of fuel left presumably means that even the most forgetful etc. can't run out of petrol.
Last week I went 13 miles past 0 miles/refuel and put in 46.64 liters, in theory about 22 miles of fuel left. The light comes on at about 50 miles to empty and then leaves you guessing at 35 miles to go,. I love a bit of petrol roulette but this does mess with me, then at the same time it would annoy no end to fill up at 285 miles with so much fuel left in the tank.
Does anyone know if it's a Toyota thing?
We had this in the Mk2 RS on that forum too as it had a slightly larger tank but Ford used the ST sensors/setup so owners were finding they could go way past the 0 miles too. I've experienced it in other cars over the years as well so they must just use a generic setup/system/software across the range but the tanks differ to each model... who knows... :unsure: o_O 😅
There was a bit of a competition over on the Skoda forum (Briskoda) to see what range could be managed in a Skoda Citigo.
I managed to get over 80 miles from light on to empty in my son's Skoda Citigo, which resulted in just under 600 miles from the 35 litre tank.
Another forum member did even better, but he managed to get 85 MPG rather than my poor 78.
As I'm only managing 23mpg in the Yaris I appreciate the early warning!
I’ve gone deep past “empty” on every car I’ve owned, my rule of thumb is that at empty/0 miles range, there is generally a gallon/5 l left, usually backed up by what the tank will take.
The other day it was about 15-20km since my Audi told me it had zero range, so with a nominal 70 l tank there was probably still another 15-20 of range.
I only took this shot to show my wife, first over €100 fill 😕
Most vehicles have a couple of gallons / 10 litres left when the light comes on - enough for around 50 miles / 80 kms. Modern bikes seem to be the same.
A bit of a change from my old XT500. 80 miles to a tank and around 8 miles on reserve.
Running low often could shorten the life of the fuel pump, if Yaris's use the fuel to cool the pump (as many modern vehicles do)
My 7.5 Golf was pretty honest, lowest I got was an indicated 5 miles to empty and it only had a couple of litres left. Used to be able to go past the clicks when filling and round up to the nearest £. Not gonna lie first time I filled the GR, I overfilled it thinking it would be the same, have never done that before o_O.
Word. Probably fine running real low if pootlin' around, less good idea if gunning it.
I think I posted this on another forum the total tank size is 50L with 6.5L reserve and 43.5L until empty.
I suspect the real reason for such a large reserve is fuel starvation due to the cars ability to attain reasonable g forces (for a street car) (launch, braking and cornering)
My rule of thumb is "never run a red light" you just end up sucking crap from the bottom of the tank and putting through the engine
Nearly all fuel system draw from the bottom of the tank (where all the crap is), and have a filter so you won’t mitigate this. All your fuel will be pulling through the crap all the time hence the need to change fuel filters
Surprising how few people realise this.
On older vehicles (like the Rover R5B I had), you had to pull a lever when you got to "reserve" which enabled you to take fuel from the bottom of the tank. On a few of my older motorbikes, the fuel tap had to be manually turned to "reserve" which similarly opened a lower inlet to the tap.
With the advances in modern tech, the fuel always comes from the lowest point and a light comes on when the float gets below a certain point.
Indeed, even on the vehicles with a reserve which was lower, it made sense to use it regularly so that any debris was collected by the filter over time and removed when the filter was replaced, rather than having years worth of debris arrive all at once on the occasion that you do have to get close to the bottom of the tank
Indeed, Haha yes fuel gauges in motorbikes only came in 2000s, nothing like the first ride on a bike to gauge how many miles till you reach "empty".
Nothing beats slowing down on a dual carriageway to traffic lights, pulling up between two cars, ready to launch and the bike cuts out when you pull clutch in! "shit shit, switch to reserve"
I always refill my cars when they’re around 50%.
It‘s much cheaper to fill up that way. 😂🤣
I do it the other way, I only ever fill it half full, least that way I'm not carrying half a tank of petrol around all the time for no reason!
I carry it around in case of a zombie apocalypse. 😂🤣
Thats also why i still have the OEM exhaust.
With this very silent car, i can just sneak around in Zombieland without being detected, while all those Milltek Drivers get eaten. 🤷🏻‍♂️
:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Haha and I'll drive past you on my howler and tell the zombies that my GR is doing better than yours.
Only hooned it once on a low tank, but that was a couple of days after someone tried to break into the house to rob it. At the time I thought I might as well have a bit of fun in case they came back and as a plus it would dampen their spirits when they found out it was almost empty.
If someone does nick a Yaris the warm up boost limit is gonna surprise them, they will hopefully think it’s slow and ditch it 🤣😂
thats where the fuel pick up is and not only that when you fill it up new fuel will swirl whats in the tank...having said that most fuel tanks wont have much in them as majority these days are plastic...
