GR86 GR86 performance figures and lap times
Yotayoda
Devoted member
The GR86 seems to perform slightly better than official figures suggest.
Don't forget car & driver knock 0.3s off their recorded time for the 'rollout' so that's a 0-60 of 5.7s
They also got a 5-60mph time of 6.5s from a rolling start, which is a bit poo.
What does that mean?
American 0-60 times are not from a standing start, they officially start timing once the wheels have rolled past the first foot. To account for this, C&D record what we'd call a normal 0-60 time and then subtract 0.3s from it. So to get the UK equivalent 0-60 just add 0.3s to C&D's figures.
That's pretty meaningless isn't it?
It measures throttle response - if the 5-60s is higher than the 0(ish)-60 then there's a bit of lag in the powertrain since it's started at the point they floor the pedal.
Thanks
Isn't there an issue there that means the result is overly affected by the amount on torque at low revs, and also the gearing?
Affected, yes. Not sure about overly since that's the point of the test, to simulate a real pull from slow speed up to freeway speeds - they'll still be in 1st at 5mph so it's not highly affected by gearing other than the usual trade off between torque and speed - go for short gears like the GR86 manual and you have more torque at a given speed, but you'll run out of revs and have to change to 2nd. Think it'd be the same in most cars bar more exotic stuff that could get to 60 in 1st.
It's not an in-gear pull - they have other tests for that like 30-50mph in top gear.
But no one is ever cruising at 5mph, and then putting they're foot down. That's what the 30-50 etc tests are for.
Obviously. 5mph is walking pace. But if the revs are low, a car may not get going very well.
Over here, yes. Stateside (which is where C&D are aiming) it's not at all unusual to pull from a junction that you've crept around at ~5mph up to 55+ for a freeway.
