My dog can do it in 5 minutesHow do the door cards come off? I take it that it doesn't take long to do?
That's great, can you ask it how? Are there screws or is it all with a spudger to pop clips?My dog can do it in 5 minutes
She said 'Woof'.That's great, can you ask it how?
Sorry, I didn't understand her instructions. I've tried google translate but no luck.Are there screws or is it all with a spudger to pop clips?
There are 3 screws - one in the door opener recess and two at the bottom of the indent in the door handle, all behind plastic covers you can pop out with a trim tool.That's great, can you ask it how? Are there screws or is it all with a spudger to pop clips?
She said 'Woof'.
Remove screws then work your way around the door card popping out the clips. Firm tugs and/or trim tool. When the card is loose it will hang from the top. Lift up to release top edge and card will come away.
Then release 2 X door opener/lock cables, 2 X wiring harness plugs from door controls and the power cable for the puddle light at the bottom to free the door card completely.
Cracking. Where'd you order from?
I've just finished installing the Focal kit - it works - nothing needed modifying - it all fitted just like OEM - it sounds better.
I had the tweaked setting to make it sound as good as it could yes.Presumably before the install you had the recommended audio settings. After the install, have you kept those settings, or started again? And how much better does it sound?
AwesomeI've just finished installing the Focal kit - it works - nothing needed modifying - it all fitted just like OEM - it sounds better.
Will do a write up when I've got a mo.![]()
