GR Yaris Diff oils
Sturesmyg
pianofingerpower
Hello!
Car is going on for its 10k service.
Should I ask them to change the diff oils or nah?
They suggest using “Toyota Genuine Differential Gear Oil LT SAE 75W-85 API GL-5”
Yay or nay on change; if yay: is oil ok?
They did suggest an engine oil which was not up to this forums standard the last time (not API SP), so not a 100% confident in their knowledge.
Front diff is inside gearbox btw. Had mine changed at 2000km as run in service as Torsens lose quite some metal from new, will soon change myself at 20000km interval (half factory), car only used on street. For track use much more often.
For whatever reason, in my notes, I had transfer and rear diff listed to use different oils:
Transfer box:
Revenol MTF-1 75W-85 Fluid: https://www.ravenol-direct.uk/ravenol-mtf-1-sae-75w-85.html.
Rear diff:
Revenol DGL 75W-85 Fluid: https://www.ravenol-direct.uk/ravenol-dgl-75w-85.html
Safe to just use the DGL stuff for both?
That's what everyone says. The MTF-1 is a "simple" gearbox oil while the DGL is "fancy" with additives for a limited slip diff, since they cost near the same the apparent logic then is that you can put the "fancy" oil in the "simple" transfer box, but NOT the other way around.
Reactions: 6mt
