Ulter exhausts... well. I know them from some NC and NB MX5s. They may sound okay ish. But the stock exhaust should be from better quality and have better flow. I personally would not waste money on them if you have the stock one or an other aftermarket exhaust.
Thanks. Quality well it's 304 stainless steel, same as everyone else, maybe the Mazda was cheapo matrrials? Welds - warranty 5yr and they use weld robots. Flow - 70mm throughout with mechanical damper and less sound deadening, hard to see how it will flow much worse. The price is tempting as I can't lose much if I don't like it and frankly I find pricing on GR exhausts quite rediculous from the others, then fear of losing out may make it harder to switch if not 100% happy.... Whifbitz excluded.
I may eat this words later 😬... Rabbit hole for me at least 🤓🤣
Watching with interest 😁
The MX5 ones I've seen were poorly welded. After 10 000 km one muffler was rattling like a viper. The reflector plates got loose. I think it was made in Poland? But don't now. That's some years ago. So maybe quality got better.
Happened to me twice on Milltek in the past so paying more isn't a guarantee... We'll see 😬
They have serial numbers and are programmed in at their correct position. So if you swap the wheels and tyres around they will be reporting the wrong tyre.
That’s interesting as I’m pretty sure I tested this theory when I rotated mine and it worked out the correct position itself. I know my last car worked it out itself although quite how I’m not sure, the signal strength changes must be tiny (similar system).
I may have made the Yaris relearn but didn’t have to reprogram . Easy to check just swap a wheel and let the tyre down.
Swapped mine round and they learnt within a few miles
Just got back from a nice run in the GRY, many winding B roads that were wet and on some bends lots of leaves. Once again this car amazed me, so much grip and handling on tight bends where the roads were wet and covered in leaves. I'm just buzzing
That was one of the reasons I was so attracted to this car. Driving near my house is mostly on country roads, covered in mud, leaves, and most of the time - water. Always felt "limited" in previous cars. The GRY still amazes me, and gives that buzz!
I forgot to mention the Audi that was also on a mission, but that's all behind me and in the passed, it tried and failed to meet the acceleration and overtaking capabilities of this incredible piece of engineering. I love this car
Wonder if it depends which way the tyres are rotated. My thought is if you rotate a back right to a front left (iirc backs swap when they move forward) the car might be able to tell they've been changed because the wheel would be rotating the opposite way?
I wish I could put put this to bed with actual facts for this car but I don't have them.
But in my mind each wheelwell has its own receiver, not exactly in the top just somewhere near where there is a wiring loom that goes around the car anyway which then communicates on the canbus wiring to a dedicated ecu for the tyre pressure warning system.
Run in the engine, sort out some minor issues and than hopefully map it.
Nothing much, just had a Tesla Model 3 Dual Motor come storming up behind me. Then I found some twisties and then, oddly, I didn't after the two corners... but I did once it all straightened out again.
That's just a bad driver, you can drive them pretty hard 😬
Job jobbed.
Didn't have a pry tool, and couldn't find one literally anywhere around here. Took me about two hours, but a large portion of that was getting the old one off. Don't think it was too bad for a first exhaust.
I like it a lot, it feels a similar volume to stock tbh but just has a lot more character. Exactly what I was looking for to be honest.
All I want to do now is add the black pieces at the bottom of the car and I think I'll be happy
I will say though after all that... I'm exhausted
I'm here all week
