GR86 Tyres pressure reading BAR to PSI?
Mick
Lincolnshire
Am I been completely blind or is there no way to change between BAR and PSI on the tyre monitor display?
Two posts from American owners on reddit show the display reading in PSI..
Reddit Link
Reddit Link
Nope....not that I can find. Quite irritating. I'm so used to PSI that it's one of the few things I don't mind continuing to measure in imperial.
Seeing as I cant change the GR from BAR to PSI, I have instead changed our other car (Kia) from PSI to BAR so at least I'm not having to switch between units whenever I check pressures.
Fields are probably only available by region. On the Skoda's if you set it to region Australia it would change the digital speedo from KMH to MPH. You still had the dial KMH so was fine if you went to Europe
I wonder if its something that can be changed using techstream.
I may take a look at some point. The thing is, Techstream is a pretty clunky, slow, unintuitive bit of software to navigate (at least on my cheap laptop). Unless you know which setting you are looking for, it would be a bit tedious to search for it. Also, I reckon @KobayashiMaru86 is right that its perhaps a regional setting; you might be able to change that, but I wouldn't for fear of upsetting something else.
isn't there a units setting in the dash screen options menu?
Only switch "miles, MPH, MPG" to "km, km/h, l/100km" . Pressure reading stays on BAR.
If it is not linked to the units setting then there is hope it is set separately/independently via techstream.
Thank you @Conscript for taking the time to look.
Even better if you can view the temps and pressures in track mode. But I think were asking for too much :ROFLMAO:
That's way too logical. Although given it's a digital screen and no doubt "locked down" for all sorts of legal reasons, I wonder if it could be reconfigured.
On a slightly tangential note, has anyone played around with tyre pressures much (both altering the outright PSI figure as well as tweaking front-to-back balance)?
I’m currently on 2.1 all round and it still seems pretty sharp. Might increase the front a bit
I'll fire up the laptop and take a look later and let you know.
A week and a half late but I finally got around to looking at this this afternoon. Unfortunately, completely fruitless. I managed to find the "Tire Pressure Monitor Live" section in Techstream and licking "Data List" brought up the screen similar to the screenshot above. However...on mine, not only did it already show the unit as "psi" (although "psi(abs)", not "psi(gauge)" ), but it also showed the pressures reading as around 49psi...which they most certainly are not! Double clicking the value didn't seem to give any options to adjust.
Interestingly, the tyre temperatures look about right - the outside temp is indeed roughly 20/21 degrees today.
Looking at the dash at the same time you can see they are reading roughly the correct pressures, albeit in bar.
I am guessing that even though the TPMS reports in PSI in Techstream, that there must be another setting somewhere which controls the gauges. I had a quick look, but couldn't see anything obvious in the Utility section, which is where other customisation settings reside.
Is there a language or country setting where you could choose USA? As that may use PSI but then your MPG will also change to US gallons so will be reading wrong.
Possibly. Which is why if there is such a setting I wouldn't want to change it. Guess I'll just have to get used to using bar now.
Absolute pressure measurement is from a vacuum, gauge pressure includes atmospheric pressure. Most pressure readings are measured in gauge, absolute is quite specialist and can add confusion.
0 psi gauge is 15 psi absolute. So your 49 psi absolute is 34 psi + 15psi (atmospheric pressure).
Doesn't help fix the problem but a bit of pub knowledge for you.
Oooh that's interesting. Ta!
