GR Yaris My first fault with car, TPMS malfunction
Chrisnufc
Absorbed member
Anyone had this?
Tyre warning light came on, checked pressures on dash and says malfunction visit your local dealer.
Taking it to Toyota shortly
After about 30 miles and 3 cycles it went back to normal took it to garage anyways they couldn’t find nowt wrong so just reset everything they said computer must of had a temporary wobbler 🤷🏻‍♂️
So while driving home today the fault came back ffs same again tyre light started flashing for a few minutes then went solid light and malfunction warning so the dealer done f**k all now gotta waste more time taking it back to dealer
I’ve had that since new. Hasn’t bothered me enough to do anything about it though. It’s just one more warning light on the dash.
It’s new for me and when your going 70mph+ and dunno if your tyres are losing air or not last thing I want is to ruin these wheels by having a blowout or something g
I use my gr daily up and down the motorway, my tpms are always going off and just learnt to ignore it, plenty of times I've checked the pressures and they are fine, I'll be glad once I get new wheels and tyres fitted without the monitors, I don't care if the lights on the dash constantly.
I mean if you have a sudden catastrophic failure then TPMS is hardly useful anyways and a slow puncture is pretty easy notice on the steering wheel and you'll have plenty of time to pull over before you are running on the bead of the rim. It's not like you're going to drive for hours on end with continuous opposite lock on the motorway and think everything is dandy.
But agree, that it's annoying that dealer failed to fix it.
Only problem is that in a couple of years time when the first MoT is due, a TMPS error like that (or missing TMPS valves) would be a fail unfortunately so at that point you'd have to get it fixed...
Reactions: Jip
Did you ever get anywhere with this?
I've had the same issue & the dealers found no issues.. They are saying that it's because of the tire sidewalls being too thick (Cross Climate 2s) and that it'd be fixed if I changed to Pilot Sport 4 tires, which he conveniently tried to flog to me for £160/..
Sounds like bullshit to me!
Because it is bullshit!
My winter set up uses Goodyear Four Seasons and OEM Toyota TPMS valves etc. I've had no problems and there is no technical reason why there would be.
Service "Advisors" 🤬 Something is thick but it's not your tyres sidewalls!
Yeah that's my argument, but they aren't having it.
Wouldn't even entertain Pilot Sport 5s.. Has to be OEM tires. At least it's not just me with this problem.
I run Crossclimate2 and have no issues at all, standard TPMS. If anything, I'd think the Crossclimate sidewall was thinner than the PS4S anyway? It's not as stiff, and it hasn't got a lot of rim protection!
How do you find the noise in the cabin compared to the PS4S?
