GR Yaris Brake bleeding tool
Grant zoo
Absorbed member
Good day to you all.
I would like to change the brake fluid my self as it one year old. Would like to get a pressure unit to help with this job. All the units I can find have a 44mm cap that does not fit.
so what size in the GR brake cap?
Plus it needs to be an angled one as not a lot of room?
have tried universal ones. But no room to fit it.
what makes are available?
Grant
Grant
Try a suction one not a pressure sure one and do it from the bleed nipples
Hi I am glad that I am not the only one how cannot find a press unit that will fit.
Also looking into this... often (not yet for the GRY) I use a vacuum /suction kit but I agree: "it sucks"! 🙃 just because it often leaks between the bleed-screw/caliper threads. it helps if you grease around the bleed nipple but it's messy...
Hello, can you let us know if this fitted and worked ok? Some of the stuff on aliexpress is best described as junk!
Have not yet used it. Will report back when I do
Cheers thanks for that I've got a Motive bleeder too, care to elaborate on any problems?
Nothing biggie - to make it perfect would require a hose joint or similar - i just used force and hose clamp but seems to work ok.
Ordered an aliexpress kit for motive. Plans to flush brake fuilds - 1ltr way to go on fluids as 0.5ltr likely not sufficient ?
using this (s06) adapter
That link no longer works. Also, searching for "s06 adapter brake bleeder" doesn't really yield useful results. Can someone point me to a product that looks like what was discussed here?
Thanks!
Thanks!
I have this
Can anyone who has changed their brake and clutch fluid recommend how much to have on hand?
1ltr, 1.5, 2ltr?
The question was asked above but without a reply. Hopefully the info will help others too.
Thanks
