is that north of the Thames then ??Alastaro Circuit - the usual here.
Its a "power track" with three longish straights but ok track with safe runoff areas.
Alastaro Circuit - Wikipedia
en.wikipedia.org
en.wikipedia.org
few clicks yeahis that north of the Thames then ??
Madness, this salt on the streets... Looks like it was fished out of the sea.Not sure if placebo but would say with endless fluid pedal feel improved. Or then there was just air in the system, fluids were 1yr old.
15 year old motive bleeder worked flawlessly - superb quality.
yep - even though its corrosion protected I find it difficult to believe there will be a car left after Toyota's 10 year warranty. All nuts and stuff seem to be quite heavily impacted so might be smart to replace few items once in a while..Madness, this salt on the streets... Looks like it was fished out of the sea.![]()
Have you seen the new "extra" track? I'm going to Alastaro 29/5 and we were told that they added a few km worth of track for us to test.Alastaro Circuit - the usual here.
en.wikipedia.org
Yes I think i know the new route - will be fun with new fast corners! Are you coming with GR Yaris?Have you seen the new "extra" track? I'm going to Alastaro 29/5 and we were told that they added a few km worth of track for us to test.
Wasn't planing on taking it but my M3 is not playing ball at the moment so probably taking the Yaris instead.Yes I think i know the new route - will be fun with new fast corners! Are you coming with GR Yaris?
Cool - Im also there likely from 17-> - would be cool to see your little rocket!Wasn't planing on taking it but my M3 is not playing ball at the moment so probably taking the Yaris instead.
I'm afraid we are leaving for the boat at around 17... We'll be driving the whole day so if its possible swing by earlier so I can give you a ride. (If you want of course.)Cool - Im also there likely from 17-> - would be cool to see your little rocket!
Definitely! I'll try to shedule earlier arrivalI'm afraid we are leaving for the boat at around 17... We'll be driving the whole day so if its possible swing by earlier so I can give you a ride. (If you want of course.)
most likely yes. as all plastic bits underside.Any underbody scoop is in for a rough ride... Best to remove/winter prep car?
Did you post oil cooler setup photos? Are you doing some airduct from cooler to this slot?Old blocking plate back and little extract slot for oil cooler hot air
That was the initial idea but no room to air channel due to oil feed lines go from there so using air from fog light and upper area - maybe its sufficient for occasional track use..Did you post oil cooler setup photos? Are you doing some airduct from cooler to this slot?
Yup, winter routine:most likely yes. as all plastic bits underside.
@Diyman25 has this solution, I plan to replace mesh with Alu fan grille so the water from wheels doesn't enterDid you post oil cooler setup photos? Are you doing some airduct from cooler to this slot?
yes I know. Its maybe efficient way but on long term the cell will be dirty and air is not going that well through.Yup, winter routine:
*future upgrades, but never too soon to start planning
- swap wheels and tyres
- swap undertray for skidplate
- rear diff vent off
- toe out rear
- swap extra long beam for fog lights*
- swap vented hood for stock*
There is a aluminum rear diff vent by Airtec, but it looks to be directing air at diff rather than ITCC.
View attachment 17899View attachment 17898
I know about Diyman25 solution, but it's perfect for clear road and warm country. I have winter and spring/autumn with muds, and oil cooler will be cover this mud. I speak about thisYup, winter routine:
- toe out rear
