is it now you will fit NS-2R? ...I'm interested to know what you think about them- booked the tire service for thursday so ditching winters and putting semis on winter wheels.
yep getting them on wheels on thu. I'll report once get few miles done.is it now you will fit NS-2R? ...I'm interested to know what you think about them
yes or was it 2.2 neg at front. its 260mm section (what manufacturer claims), but spec yes 255mm.255 et45 with neg 2,5° with camber bolts, correct?
AWD - no issues! Garage front melts always last, quite dry roads already but worth being cautious in the evening/early morningsBold choice in those conditions!![]()
set up a separate thread for the tire. Added initial impressions.that's a proper tidy oil take off system right there with those banjo connections
do update your thoughts on the NS2R as they are one my least favourite tyres
what track ??First track day for the year coming on next Monday. Stuff to do
- add HRNS's brake cooling ducts (removed the pipes for winter as they are wear item)
- swap the brake fluids (maybe if have time - current fluids 1yr old.
Goal for this year is to take 2s off from last summers PB - on first visit not expecting to make much wonders.
Alastaro Circuit - the usual here.what track ??
