GR86 A/C recirculating mode self activates
GRpirate
Hampshire
Hi all has anyone noticed the recirculating mode coming on by itself. I have done about 4k miles and in the last week I have to switch back to fresh air about once every couple of hours. Anyone else noticed this or is it a fault that developed. Thanks in advance
Funnily enough I came on here to search about this in case I was doing something wrong on my settings.
Spotted this today on my drive too, happens more frequently then the once every couple of hours for you though.
I’ve noticed it as well, did it to me today, glad I’m not imagining it, or have a fault. Maybe it’s doing it as part of the automatic setting, and would turn itself off again if left long enough? I even resorted to reading the manual, but didn’t see a mention of it.
Thanks Nick for your reply. It’s bit strange and annoying can’t see any reason it would do this.
I believe it's a feature when you select the "Auto" climate control setting.
My BMW 5 series had a similar feature where it would enable air recirculation automatically if it detected high levels of pollutants outside.
Usually it depends on the temperature difference between the inside and outside. If the inside of the car is warm but it's quite warm outside too, recirc is enabled automatically as it will cool the interior more quickly.
EDIT: Checked the manual...
Thanks all conscripts nailed it there in the manual. Just have to use manual setting if I won’t to avoid it
Thanks for finding that, I guess that was the electronic manual? I only checked my printed hand book and didn’t spot it in there.
Yeah if you log into your account on Toyota.co.uk and go to your vehicle there should be an option to download a .pdf of the full manual.
The automatic selection of the re-circ can apparently be coded out in the vehicle settings. Another one to add to the list for when I get round to it.
My recirculating mode kicked in for the first time today (at least the first time I have noticed it). I'd driven the car 35 miles earlier and got back in about three hours later. 14 degrees outside, I wanted 19.5 inside and pressed 'auto' (with aircon on too) and the recirc came on.
I thought I'd leave it to see what happened, and it turned off after about 10 minutes.
Perhaps we can file it under 'nothing to worry about '.
Unless some of you are so enraged by this you are immediately going to swap for a BMW 2 series or a Supra
I was out today with the heating completely off and the recirc lit up on its own. Not sure what triggered it, at least it appears not to be a fault.
I get a strange sweet cherry bakewell smell whenever the recirc comes on, my GT86 was the same.
Even using manual the recirculation does still come on. I haven't had my AC on auto at all and this is a common issue I seem to have.
Every so often i wonder why i'm uncomfortable and check, once again recirculation is lit up
I think we have had 1 hotish day so far, and I was terribly underwhelmed with the cooling performance, need more time to confirm but I am concerned.
When you say "using manual"...what do you mean? Do you mean, you are adjusting the fan speed and vents, but still leaving the AC on?
Because I don't think recirculation has anything to do with the "auto" setting. I think it simply compares the requested temperature you set on the dial, then compares the current inside temperature, the current outside temperature, and if it would be more efficient to recriculate the inside air, it will flick on. Every car I've owned with AC and a recirc function has stipulated that it should be used for "rapid cooling of the vehicle interior" or similar, as it's more efficient to keep cooling down the same air from the interior, rather than constantly drawing in warmer air from outside to cool it. I think it's probably enabled when the AC is turned on, regardless of whether it's set to "auto" mode or not...perhaps experiment with turning off AC just to see?
I don't have my car with me at the moment to test it, but it was the same in the GT. My dials were always set to 21 degrees, and recirc only ever came on if it was a hot day and the car was trying to cool the interior to that value. It would switch off automatically once the temperature inside reached the desired 21 degrees. However, even on a cool day, if you turned the dial to the coldest setting, recirc would still come on.
Silver Fox file under nothing to worry about you nearly had a breakdown because there’s no coat hooks 🤔 I am the same as moon balls I only noticed it because you get a change in your environment. For me the air starts to feel stale and then I see it’s on again. I am sure I can live with it now I know it’s not faulty. Thanks for all your comments
And there I was, gradually beginning to come to terms with Toyota's egregious interior accoutrements error, and you had to go and remind me.
*Breakdown mode activated*
