GR86 16s
PaulT
Dedicated member
Berkshire
Now we are talking 😁 I didn't find the ride on 18s particularly bad, but I cringed with every pothole. The 16s smooth things out a little bit, and this combo of Pro Race 1.2 and Yokohama BluEarth GT is a few kg lighter than the stock 18 with the PS4. You do feel that, it does seem more responsive.
There's less absolute grip, quarter throttle in the wet and it spins up the rears off the line. Also feel that the diff is helping the back round much more easily on a low-speed roundabout. Exactly what I wanted, and I like the fat tyre look, although it seems the market prefers a bigger wheel cosmetically.
Abingdon track day in a couple of weeks, will see how they handle when pushed. Interesting to see in the meantime if the slightly thinner (205x55r16) eco tyre improves the fuel economy.
Good going, enjoying a different route. Had a good similar stint on the predecessor, I learned that wheels can actually be too light, so little inertia and so mobile that the car felt unstable at high speeds, also messed up the damping (too stiff rebound). 12,5kg for the whole wheel combo (tyre+rim), also 205 wide ...(worked fine as winter wheel set...)
Looks so cool on 16”s - what’s the offset & width?
TE37? I really like those. I've never heard that a wheel/tyre could be too light before. Is it possible that the tyre could have been causing the problems? Appreciate that an expert might match the side-wall stiffness to the dampers, but for me I've never had a problem, lighter has always seemed to work out better,
16x7 with offset around 35-38, can't remember exactly. I think they could do with being tucked in a little, maybe 40-45 or so, but they are just about inside the arches. Brake clearance is not an issue, there's plenty of space radially and between the spokes and calliper.
A 7in width gives a very small stretch to the 205 tyre, like the 7.5in does with the stock 215. I need to weigh them, but I almost wonder if going even lighter with some Rays would be nice 😁
Yep, forged TE37 off an original Impreza STI mk1.
Yes it was the tyre, incredibly thin sidewalled Goodyear EfficientGrip, 7,3kg. Worked well with heavier winter tyres, obviously not as high speeds either. But the feeling of lightness at the helm was fantastic. Later went 17" with the same tyre as summers and that was sweet spot.
I'm also more of a fan of the meaty tyre route rather than the stretched rubber bands on alot of new cars. It looks good, it doesn't look like a skateboard, alot of it is down to the wheel design and colour I think, nice one. What's the width and offset Paul?
Rim width 7in, offset is around 35-38 I think, the wheels aren't stamped and I can't remember what I originally ordered as they date back to 2017. Could easily go 10mm larger on the offset, there's plenty of brake clearance on these wheels.
top work, i’ll be joining you as soon as i find some wheels i like πŸ‘πŸ»
Some people scoffed at me when I changed the silly 20" wheels & 30 series tyres on my FK8 to 18" wheels & 40 series tyres.
After 3.5years I can say its by far the best thing I have ever done & its the only "mod" I have done on the car.
Unlike most FK8 owners I have never suffered a puncture or worse still damaged a wheel.
I am happy with the 86 OE wheel/tyre set-up, I just wish the suspension was slightly softer.
It amazes me how people are more bothered with how a car looks (big wheels) than actually how a car performs & feels with day to day driving.
I have a set of 205/45 R16 Nankang NS-2R that I was about to sell (from my old MX5) would it be possible to get a set of wheels that will fit the GR and take those tyres?
Those tyres are a too small in circumference and will reduce gearing by over 5% and, unintentionally, lower the car 17mm. Sell the tyres unless you're only doing autocross or similar on them, then they are perfect (yes you can find rims for them in such case).
Thanks πŸ‘πŸ» I'll continue with the sale
The stock wheels and tyres are 215/40 r18 right? The same as the on the i20N I think, and loads of i20N drivers find their wheels are very susceptible to damage from potholes etc. Are people finding the same issue with the wheels on the GR86?
If so I wonder if 17s would be a good option?
I don't recall seeing anyone mention it but then again there isn't many of us on the road. 17s would be a good shout, they use them on the base model in other markets.
