GR Yaris Has there been an update to the multi information display?
GRgrampa
S. Wales
I tend to have my MID set to show the boost and oil pressure and temperature gauges.
Driving a friends GRY the other day and I noticed he had a digital speedometer on his display. When I got back into mine I scrolled through the settingd but couldn't find this one anywhere.
His car is a November 2022 CP and mine is a May 2022 CP.
Anyone know if this has been part of a software update or did they change the display at some point?
There is def a digital speedometer. Scroll through the things and it will turn up.
Digital speedo is on the main section, not one of the advanced ones like the turbo, awd, or tire pressure ones.
I'm nearly always on the turbo one as it shows the oil temperature.
Side note: it's modestly infuriating that we can't re-order the panels and that the two most useful ones (the one with fuel economy/speedo/etc and the one with boost/tire pressure/etc) are as far apart from each other as possible.
Side note: it's modestly infuriating that we can't re-order the panels and that the two most useful ones (the one with fuel economy/speedo/etc and the one with boost/tire pressure/etc are as far apart from each other as possible.
Damnit, I demand a refund! :D
It's mildly annoying that the Waze "next instruction" graphic will appear in that panel, but won't show on the HUD, whereas the built in navigation will appear on both.
