GR Yaris Quaife ATB differentials
Lanman
Brisbane
Hi all best news yet for owners without Torsen diffs . Quaife UK are to make their brilliant ATB diff for GR with open diff .see attached email I got today . Hooray!!!!
These are fantastic diffs . Go for it !!
So nearly £1,800 for the pair. What do we reckon fitting costs are on a pair of diffs?
well that's interesting, think I remember seeing somewhere on the 'other place' it's around £1500+ quid just for the rear torsen LSD not including shipping
Definitely cheaper to add these and a set of more modest (than Circuit Pack BBS) forged wheels to a Convenience Pack than to add HUD, parking sensors, uprated audio, parking sensors etc. to a Circuit Pack
No chance. £1,800 plus fitting then some modest forged wheels £1-2k could easily be over £5k. The HUD would be the most expensive part to retrofit, good audio and sensors could be had for under £1k so that leaves you £4K to retrofit the HUD, not that I think anyone would want to do that. (Obviously I’ve not included the original cost of the circuit pack in that).
And that’s the kicker. And you can get a set of lighter-than-BBS forged wheels for about a grand .
Based on quotes for other cars over the years, I doubt the labour for fitting the diffs would be more than £1000 if doing both ends at once, although who know with current prices due to inflation.
And the sat nav module isn’t pennies either.
For those on limited budget could fit rear diff only as much easier fit . These diffs are beautifully made . Had one I fitted to early 135i before BMW welded in the diff Centre . Just bolted in . Now need complete unit for BMs which they do on exchange. This is a far more sensible way to improve traction than a plate Diff . For hard arsed rally blokes plates are the go I guess, but fast road track day simpletons like me , these make sense !
Sorry was thinking standard vs circuit.
There was £1,320 difference between the 2 so that’s your wheels and tyres.
So £2,800 minimum (based on your £1000 fitting costs) to buy and fit the diffs.
Upgraded audio that everyone seems to be fitting is £250, checkatrade says the current average for parking sensors is £325 fitted OEM Yaris set is £750.
The nav unit is £750 although I think you’d be hard pushed to justify why you’d use an OEM system vs CarPlay/android auto, likewise the HUD I’ve seen comments it’s only good for city driving. Buying direct from Toyota the HUD and trim is £1400 although has been done with a secondhand HUD for under £700.
So buying direct from Toyota there’s £100 between the two estimates.
Everyone has their reasons for buying standard, convenience, circuit but the best deal was and will always be the circuit pack cars in terms of sum of all parts.
Absolutely correct. The so called Rallye version sold down under has all the gear including heated seats and steering wheel , great marketing in a hot country where the sun shines ! Have used the seat and wheel heaters a couple of times in freezing morning temperatures and a great luxury !! The Torsen diffs are brilliant as I found out in soft sand with the car on its belly!
Hmm those looks to be heavier than factory BBS?
And maybe Just thinking of what package is most suitable for a driver, evetually they both cost more or less the same money.
pricing is out - £665.00 ex VAT. keen to have one shipped down under
I think you will find Quaife have Aus agents who mark up like crazy !
Toyota quoted me around £3,200 for the rear LSD alone. Instead I found a whole rear CiP suspension assembly on Ebay for a grand and had the Torsen diff swapped to my Conv Pack for a few hours labour. About £1300 all in I think.
Added bonus was getting a spare Centre Clutch Pack in the deal :D I do wonder how long these will last on our cars. Nice to know I have a spare, I doubt they'll be cheap from Toyota either.
Do these Quaife diffs do anything different or better than the OEM? And will they need maintenance?
Quaife make an absolutely beautiful diff but a second hand diff as yours is would be just as good but they don’t fall off trees ! The clutch packs have the regular warranty and should not cause any bother unless you tweak the car a lot ! Torsen diffs are great in road use but a clutch pack plate diff would I guess be better for racers and real Rallyers !
Evolve quoted me 2.5k to 3k for a used when a brand new one costs 2.7k (Before shipping). that said, OEM Torsen is good to retain warranty. Pretty sure the moment you drop the Quaife in you will void the driveline warranty.
Having fitted one myself to my early 135i before BMW started welding in the diff centres They are a beautiful piece of modern engineering almost worth putting on a shelf at home !
