Hi Kinboshi,I'll take that as "no there isn't"...![]()
Ideally both the flap and the plastic attached to it that's round the metal of the socket. But at least the flap.Hi Kinboshi,
You can remove the flap but the surround is different. What bit are you looking to remove exactly?
You could easily make a new cover and use this USB solution and hide the existing one below.Might be a bit of a sledgehammer to crack a nut, but I wonder if there's enough clearance for a Neutrik USB feedthrough to replace the 12V?
I've used them on a couple of occasions to get a neat powered USB outlet
Skoda Octavia centre armrest
Skoda Yeti dash top box
Or course it does mean locating both the 12V socket and the USB power adapter underneath somewhere and buying one of these
But the result is very neat
I'll just remove the flap then - it's not needed!The flap can be removed by disconnecting the spring under the flap. you might damage it if not careful.
The plastic houses the metal element it what allows it to fit in the dash, removing it mean the 12V would fall below without something new being made, this part can be removed easily though.
Nathaniel
let us all know how that wentI'll just remove the flap then - it's not needed!
Definitely not needed but looks awful without it imo and very easy to break. Mine is apart if you need photos let me know.I'll just remove the flap then - it's not needed!
I have an adaptor in the socket all the time. The flap is ugly and not neededDefinitely not needed but looks awful without it imo and very easy to break. Mine is apart if you need photos let me know.
Nathaniel
And I thought you were just trying to save weightI have an adaptor in the socket all the time. The flap is ugly and not needed
Benefit of marginal gains!And I thought you were just trying to save weight![]()
