GR86 Carlinkit Android tablet box upgrade for head unit
Can anyone talk to the downside of the carsifi?
What don't you like, what's a bit rubbish?
My experience of multiple Bluetooth devices in a car is that they are frustrating, for instance are you connected to the radio and carsifi?
What happens when you get a phone call?
Was fully expecting to be able to find at least some fault when I bought the Carsifi (just because I'm always a bit skeptical about things like this), but really, it's been pretty much flawless for me. It behaves exactly as it did when the phone was plugged in via a cable....except it's not.
My phone has a BT connection to both the car and the Carsifi but as far as I can tell, this is how it's meant to be. And in that sense it's no different to wired AA anyway...if you're using AA, that becomes the cars primary way of connecting with the phone as soon as you plug it in, even if you also had a BT connection set up. Literally all Carsifi seems to do is fool the headunit into thinking the phone is connected via a cable. And given that it's tiny and can be stowed nearly under the armrest, if you didn't know, you would just assume the headunit had native support for wireless AA. Its really that wel integrated. Phonecall comes in and AA handles it.
I can't detect any noticeable lag or delay when using it. The only downside I can think of is that it takes a little longer to connect and open AA than when plugging in. But even that is being picky...we are talking maybe 10-15 seconds as most. Its ready to go but the time I've got my seatbelt on and got comfortable.
It also has some additional useful features. You can connect more than one phone to the Carsifi and switch between them using the button on the box. I can't vouch for how well that works as I don't use more than one phone though. There's also a companion app where you can adjust settings like the DPI of the headunit (this used to be useful as a way of forcing AA to show in split screen, but since Coolwalk that's not really needed anymore IMO), and there's also a setting which forces AA to not give you the annoying safety pause every few taps.
Really, I am most impressed with it. I still get the occasional Bluetooth disconnected warning on the HU...but I used to see this before Carsifi as well, when connected to AA via the cable. If anything it happens much less frequently with Carsifi so I think this might be a bug in the HU itself.
For reference I'm using a Pixel 7 Pro.
103 is the setting that gives you the biggest icons but still have the split screen. 104 loses split screen and 102 is smaller. Took a lot of trial and error!
Thanks! Setup took 2 minutes and the splitscreen is so much better.
Just to point out, that it looks like you have the latest version of Android Auto there, with the Coolwalk update.
Since that update, AA supports split screen even without changing the DPI. So if you revert it to default, you should still have split screen.
But either way, yes, it's nicer :)
For Google maps yes, but for Waze it doesn't (yet) :) I have had coolwalk for a couple of weeks now. The split screen is all DPI related in this case.
Ahh yes, I forgot about Waze, I tend to just use Google maps.
I've been looking at various options for wireless Android Auto for the car and stumbled across this:
The idea is similar to the other kits except this effectively has the guts of an android phone/tablet in it including micro sd and sim card slot. I've seen a few OEMs now moving away from AA / Carplay to built in systems like this and the specs are pretty good (8 core, 4gb ram, 64gb storage).
The biggest bonus for me is I have a the remootio app which controls my gates that doesnt support android auto. Now I'll be able to open my gates from the car screen! It would also be pretty fun to try and get Gran Turismo working on an emulator just like this guy
Although it's £15 cheaper on eBay I chose to get it on Amazon for the support / returns. Will report back with findings!
I've been using one of those for awhile drop me a line if you have any questions on it
