GR86 Android auto issues
WpR
Dedicated member
I have a new phone (OnePlus11) and since then having issues with Android Auto. Previous phone had no issues at all...
- When plugging it in, I have to select what the phone needs to do each time (file transfer + android auto). By default it selects "charging only". Very annoying and dangerous when having to do this while driving each time. I entered dev mode and put it to file transfer by default but it didn't help..
- First time after selecting "file transfer + android auto", the Toyota unit says something like "couldn't start AA because the phone time isn't set". I have to set it to "charging only" and again to "file transfer + AA" and then it works. Even more dangerous, especially because the notification is the last one so have to scroll down to fiddle around...
Anyone have the same and figured this out?
I also have a 1+, a 7T. It sometimes doesn't connect straight away, and when I check the phone it is waiting to confirm what to do charge / file transfer etc - and it connects when I select the option on the phone. Sometimes it connects immediately, without having to unlock the phone at all. I haven't figured it out yet, but was waiting to get a new cable as sometimes it doesn't recognise it at all and I need unplug-replug.
Reactions: WpR
At least for me I know it's not the cable, my previous cheap phone had no issues whatsoever.
Always something when upgrading from phone.. Pffft
Might be worth trying Carsifi or similar? I have it for my GRY, and it's so much better than having to plug the phone in each time (I still plug the phone in to a charging cable, plugged in to an adaptor in the 12v socket. But it means it doesn't disconnect at all if/when the cable moves in the phone port. For short journeys can keep the phone in my pocket.
Good idea, will consider it.
Goto Android settings, search for "About phone" or somethig like that. There you'll find something like "Build number". Tap on that 7 or more times and it will show "You are a developer now". Go back one level in the menu and open Developer settings. (maybe it's in System/Extended) There will be the option "Developer settings". Open that and change "Standard USB Setting" to "Transfer" and this will be permanent. All the names mentioned might be a bit different (depending on manufacturer). Hope this helps.
Bye for now Fred
Bye for now Fred
Yeah that's what I did, but even with file transfer on as default setting it still chooses charge only..
I’d be looking at swapping the cable. I know you’ve ruled it out as your last phone it worked but it’s quite a quick thing to check.
Reactions: WpR
Another OnePlus user here (Nord) and I also recommend the carsifi wireless dongle, bit pricey at £75, but works a treat, and no need for cables trailing round the cabin.
Reactions: WpR
Bought a carsifi a couple of days ago as well, should be here next week :)
I'm using a Samsung Galaxy S23 Ultra (previously S21 Ultra), and issues related to Android Auto and bluetooth disconnecting disappeared since switching to Carsifi, so another vote for that from me. Just make sure your phone is only connected to Carsifi and not the headunit to avoid further disconnection issues.
I still get a few issues but am sticking with the cable for now. Also found some apps are better than others. For example for my MP3's I'd used Pulsar for years but on Android Auto, while it works, it would often go to the next track but not play anything and would freeze. You'd try skipping back and forth for it to fix itself, only for it to do it again on the next one. Trying PlayerPro which is a free trial, then £4.99 for the full app but was good enough that I bought it. Seems far more stable than Pulsar and seems to connect far quicker. I like it's features too and is smart enough to know what you've added recently and seems to handle menu structures better too.
Doesn't the phone reconnect by itself when you plug it in to charge? So you have to remove the Bluetooth connection when you do? Pfft why can't this just function without neverending IT hassle. AA is 8 years old and still working like *.
As I think I've said before - I have Bluetooth on and connected to the car everytime I drive it, no leads involved. Then, on occasion I use AA by starting it from the apps button / icon, I do so wirelessly with carsifi.
I've never had a drop out or had to turn one connection on/off before starting the other.
I like the fact I can just have the radio on with AA mapping if needed. And then if the radio is crap, I put my phone's music on in AA.
It all just works for me. Android 11, Realme phone.
Carsifi and my Pixel 6 seem to be working well for me. I do get drop outs but it is in the same location of my commute every day, there is clearly something transmitting nearby to cause it as it's like clockwork.
I like to keep my phone in my pocket unless I have to charge it. If charging, it would be advisable to plug it in to a 12V quick charger in the glovebox for efficiency/speed. In which case it might be best to get a dedicated phone holder or just keep the phone in the glovebox/passenger seat when charging.
Either way, I don't plug in my phone to the USB ports in the centre console with the cupholders.
I understand the frustration though.
Reactions: WpR
I had my phone connected to the car via Bluetooth before I bought Carsfi. After buying it, I just paired the phone to Carsifi as well, but didn't unpair from the car headunit itself. That's how I left it, as it worked fine. However, even now, I still get Bluetooth disconnection errors (although usually only after being on for a while, and although the message pops up, it goes away after a few seconds and doesn't actually seem to interrupt music/nav).
I might try seeing what happens if I unpair my phone from the head unit and have it only paired to the Carsifi - I only use the phone via AA anyway.
Good to know as I have a Pixel 6 Pro.
Carsifi arrived. Works like a charm, setup took 2 minutes. DPI on 102 makes is so much nicer too (split screen). Why is this not standard..
You can get split screen with the default DPI now, which is more responsive overall and has higher sharpness.
